Mopar/Factor Fog Lights - JeepForum.com
post #1 of 8 Old 09-13-2010, 10:28 AM Thread Starter
ericw08
2008 KK Liberty
Anybody put these on a jeep that wasn't originally equipped? Any info/advice? Better to get some other aftermarket add-ons? I thought it might be nice to keep the factory look..
Jeep Liberty Fog Light
ericw08 is offline
post #2 of 8 Old 09-13-2010, 10:47 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
I was going to get them but there so much money due to having to replace the headlight housings. The install would be easy, the only part of the install i wouldn't know how to do at first is using that pick tool to pull the wire out of the wire harness.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 8 Old 09-13-2010, 11:02 AM Thread Starter
ericw08
2008 KK Liberty
Yeah they're a good bit of cash... It looks like all they're doing with the pick is removing some of the plugs from connector and loading the supplied harness. Apparently you have to get the software flashed or VIN updated or whatever to use it though...
ericw08 is offline
post #4 of 8 Old 09-13-2010, 11:13 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Ive heard that, but others have said theirs worked fine. Its probably a game of luck
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #5 of 8 Old 09-14-2010, 08:29 AM
VMF
2008 KK Liberty
your limited came without fogs?
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #6 of 8 Old 09-14-2010, 08:56 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Nope, only got a KK Sport, and added chrome after
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #7 of 8 Old 09-14-2010, 10:02 AM
VMF
2008 KK Liberty
oh gotcha
2004 UCF31. Black
VMF is offline
post #8 of 8 Old 09-15-2010, 11:33 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I was thinking about this when I was deciding between KKs on the lot. I just bought one that came equipped with fogs. Installing the new switch stalk and running wires are a PITA. The instructions sheet provided a year ago had a bit more detail, I think they give 4-6 hours tech time on this if I recall correctly. The fogs are turned on and off by the power system which needs fogs enabled in its program if not already enable. I'm guessing most are enabled from the factory regardless. .. but I dunno.
ColdCase is online now
KK Accessories - Mopar & Others Nitz240d KK Liberty Forum 13 05-26-2010 06:14 AM
Mopar black tubular side steps oldbanker KK Liberty Forum 0 05-06-2010 04:34 AM
Liberty 3.5 x factor system? T1NGNR KK Liberty Forum 1 04-12-2010 06:36 PM
ESP/BAS lights lukes KK Liberty Forum 0 03-31-2010 03:26 PM
LED lights for reverse lights Wnahikian KK Liberty Forum 0 02-17-2010 08:48 AM
