Mopar Accessories - JeepForum.com
post #1 of 10 Old 07-15-2013, 12:35 PM Thread Starter
98ZJ SFD
2012 KK Liberty
Mopar Accessories
I was looking at some of the Mopar accessories for the KK and was curious about their installation. When I had my Subaru, when I added the factory fog lights to it (it didn't come with them when I purchased it) the wiring, etc. was already run in the car. All I needed were the actual lights themselves, a relay and a dash button which all came with the OEM kit I purchased. Are the KKs the same way? For example, if I were looking at a rear view camera set up, would wires already be in the hatch and I'd simply have to plug into something? Or would I need to run all the wires myself?
I know something like the factory remote start would require a trip to the dealer but I was curious if some of the other products were something I could install on my own.
Current
2012 KK Sport, Mopar skids, DuraTracs, Mopar Grille Guard
Previous
98 ZJ Laredo SE 4.0, 2" Skyjacker BB, JKS Quicker Discos, Goodyear Wrangler MT/Rs, K&N FIPK, Kolak cat & back exhaust, Westin Safari bar, KC lights
98ZJ SFD is offline
post #2 of 10 Old 07-15-2013, 02:46 PM
lfhoward
2008 KK Liberty
I don't know the answer to the wiring question, but I know that several folks on here have added the factory fog lights. They have to be enabled by a computer flash at the dealer, but they're not to hard to install according to most.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #3 of 10 Old 07-15-2013, 02:56 PM Thread Starter
98ZJ SFD
2012 KK Liberty
Fortunately I have the fog lights from the factory. My reference was just an example of the Subaru being pre-wired during manufacturing. Apparently they build all their cars alike and set them up for various options. Whether or not they're included in the final build obviously depends on the order. It's kind of cool. I was hoping Jeep did something similar. I'd rather plug and play if at all possible
Current
Previous
98ZJ SFD is offline
post #4 of 10 Old 07-15-2013, 05:47 PM
Ted15
2010 KK Liberty
I think all of the manufacturers do. It wouldn't make sense to have a bunch of different wiring harnesses for the same model vehicle, the cost could get very high.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #5 of 10 Old 07-15-2013, 05:54 PM Thread Starter
98ZJ SFD
2012 KK Liberty
Ok so for something like the Mopar remote starter, would that simply just require plugging into an existing controller in the rig and then getting new keys? Or would there be more to it?
Current
Previous
98ZJ SFD is offline
post #6 of 10 Old 07-15-2013, 05:55 PM
lfhoward
2008 KK Liberty
Most of the electronic upgrades require a computer flash at the dealer to turn them on.
lfhoward is offline
post #7 of 10 Old 07-15-2013, 08:25 PM
xDefiant
2008 KK Liberty
So if you need the computer to get a flash jump to install fogs...what if you install fogs on a brush guard or roof? Is that still the case?
xDefiant is offline
post #8 of 10 Old 07-15-2013, 09:02 PM
lfhoward
2008 KK Liberty
If you run your own wiring, relay, and switch for your own lights, then no flash needed. But if you add a new Mopar accessory that works with the Jeep's computer (OEM fogs, remote start, cruise control, etc.), it will need a computer flash to make it active. A few accessories like heated seats are plug and play and do not require the flash because they have their own switch and just tap power from the cigarette lighter circuit.
lfhoward is offline
post #9 of 10 Old 07-17-2013, 10:16 AM
xDefiant
2008 KK Liberty
Oh ok, yea I plan on putting fogs on my brush guard in the near future. I also plan to run the wiring and use generic switches to power.
xDefiant is offline
post #10 of 10 Old 07-17-2013, 01:04 PM
lfhoward
2008 KK Liberty
Cool, the aftermarket lights should work right off the bat for you then. Just be sure you use a relay in your light circuit-- it protects your switch from seeing all the amps so it doesn't catch fire and burn down your rig. Here is a reference with some good wiring diagrams: http://www.accessconnect.com/fog_dri...hts_wiring.htm
lfhoward is offline
