Mobil 1 0W-20 synthetic oil - Page 2 - JeepForum.com
post #16 of 19 Old 07-09-2012, 05:19 PM
tjkj2002
2002 KJ Liberty
Originally Posted by bagwell View Post
careful there...you might want to add.....that is your opinion.
on the flip side ---- some tests indicate that a thinner oil (like 5w-20) is much easier/lubricates better at start-up than a heavier grade and most engine damage is done on start-up.
There is zero difference in start up protection between 5w-20 and 5w-30 as both start as 5 weight oil when cold.When at operating temps is when the difference is since the 5w-20 will be 20 weight and 5w-30 will be 30 weight.
You want thinner oil for very cold start ups(-30 degrees and below) then you want to look at 0w-30 oil.
tjkj2002 is offline
post #17 of 19 Old 07-10-2012, 06:17 AM
bagwell
2011 KK Liberty
yep, technically you are right ...but if you actually look/feel/touch 5w-20 vs 5w-30 I believe you really can tell the difference....that said, I moved from Denver to Houston and will probably switch to 5w-30 because its so freakin HOT here
bagwell is offline
post #18 of 19 Old 09-19-2012, 03:21 PM
onlyone
onlyone's Avatar
2014 JK Wrangler
5W-20 is just fine. That's that they designed for it. No offense, but I will trust them over any forum hero.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
post #19 of 19 Old 09-19-2012, 06:16 PM
tjkj2002
2002 KJ Liberty
The 3.7 and 4.7 was never designed for or redesigned for 5w-20.The 5.7 HEMI was when MDS was added.
tjkj2002 is offline
SEMI-Synthetic oil in the 2011 liberty? lonewolf5347 KK Liberty Forum 13 11-30-2011 12:56 PM
Synthetic oils? Anderson75 KK Liberty Forum 33 08-25-2011 01:38 PM
Question on Synthetic 5-30W and 5-20W bobbarto KK Liberty Forum 7 07-14-2010 10:37 AM
