Lug Nut Torque? - JeepForum.com
post #1 of 7 Old 10-05-2011, 05:24 PM Thread Starter
tonyggg
2010 KK Liberty
Lug Nut Torque?
I can't seem to find anywhere on this site, the internet or the owners manual the required torque setting when tightening lug nuts on a 2010 Jeep Liberty with the OEM 17" Wheels. What is the required torque when tightening the lug nuts? TIA
tonyggg is offline
post #2 of 7 Old 10-05-2011, 05:46 PM Thread Starter
tonyggg
2010 KK Liberty
...just found it after doing a word search in the manual. It is 95 ft/lbs.
tonyggg is offline
post #3 of 7 Old 10-05-2011, 05:48 PM
tjkj2002
2002 KJ Liberty
Standard Chrysler lugnut torque for there vehicles using 1/2-20 lugnuts is 85-115lbs-ft or torque.
tjkj2002 is offline
post #4 of 7 Old 12-14-2013, 01:45 PM
Rob K
1995 XJ Cherokee
I'm rotating the wheels. Owners manual says 95ft/lb, but it doesn't specify steel or aluminum. From what I've read they are supposed to be torqued differently. What is the correct torque for aluminum on my 2011? Does the pattern matter?
Rob K is offline
post #5 of 7 Old 12-14-2013, 10:56 PM
AtTheHelm
Its always a criss cross pattern for all wheels. I think all oem wheels that came with the KK are aluminum alloy, so 95 ftlbs is probably fine.
AtTheHelm is offline
post #6 of 7 Old 12-15-2013, 04:48 AM
bsad67
2012 KK Liberty
Recheck torque after driven 50=100 miles on all aluminum wheels. If you like to be extra safe check again around 500 miles.
2012 KK Latitude Chrome grille, chrome bug deflector, chrome door handles,
chrome mirror caps, chrome gas door and Jeep Cargo Area Liner.
AVS vent shades and factory dealer installed remote start.
http://www.forjeepsonly.com/jeep-forum/showthread.php?108-Member-from-FABO
bsad67 is offline
post #7 of 7 Old 12-15-2013, 09:54 AM
Rob K
1995 XJ Cherokee
If they only came with aluminum then it makes sense they would give only the 95ft/lb spec. Thanks
Rob K is offline
2009 Liberty Spark Plug Torque? GearGuy10 KK Liberty Forum 5 08-01-2011 08:07 PM
Rear Differential Bolts Torque rgarnsey KK Liberty Forum 2 01-02-2011 06:02 PM
