Liftgate Window Latch issues - JeepForum.com
post #1 of 15 Old 08-20-2010, 11:06 PM Thread Starter
mai-ling
2008 KK Liberty
One of our Jeeps has a an issue with the liftgate window latch.
It won't work period.
When you press the key for the window it won't budge
and when you start the car it lets you know it in the
mileage window flashing gate door.
It obviously screws up the lights inside and the illumination
of the dash at night.
We were told at the parts dept at the dealership that the
latch was no good. So we purchased the part and put it in.
Still doesn't work but the light now go on when you enter
vehicle (which didn't happen prior) and now they won't
shut off automaticly.
Has anyone else have any issues like this?
Any idea what is going on?
I think its a fuse or sensor of some kind.
Any help would be appreciated.
Thanks!
you will remember my name
World's Youngest Illusionista | 7th greatest pianist in the world | Go Red For Women and Stroke Ambassador
www.mai-ling.net
mai-ling is offline
post #2 of 15 Old 08-22-2010, 02:54 PM
richd
2008 KK Liberty
Thanks!
Are you sure its the window latch and not the liftgate thats the problem?.On my 08 KK,if the window is open it shows glass on the odometer,not liftgate.
richd is offline
post #3 of 15 Old 08-22-2010, 03:00 PM Thread Starter
mai-ling
2008 KK Liberty
it say's "gate door" on the odometer
is there a seperate fuse for each latch?
www.mai-ling.net
mai-ling is offline
post #4 of 15 Old 08-22-2010, 04:37 PM
richd
2008 KK Liberty
There is 1 fuse, cavity #M38,25 amp.
richd is offline
post #5 of 15 Old 08-22-2010, 06:19 PM Thread Starter
mai-ling
2008 KK Liberty
looked at it and it works but replaced it anyway.
still say's gate on the odometer.
could there be a relay for the window that is malfuctioning?
www.mai-ling.net
mai-ling is offline
post #6 of 15 Old 08-22-2010, 10:05 PM
richd
2008 KK Liberty
Yes,that was going to be the next step.You will have to check your wires at the module by the latch and make sure you have power going to the wires,also make sure there is a good connection,unplug connector,then plug back in,If latch doesnt work,then most likely bad module.
richd is offline
post #7 of 15 Old 08-22-2010, 10:09 PM Thread Starter
mai-ling
2008 KK Liberty
excuse me if i might be asking a dumb questions.
the module is the plug that attached to the wires that
plugs into the latch?
how do you check a bad module?
www.mai-ling.net
mai-ling is offline
post #8 of 15 Old 08-22-2010, 10:16 PM
richd
2008 KK Liberty
I dont have the specs,but if you have power going to the module,and nothing works,then most likely its a bad module.The module attaches to the latch.I looked at mine today,and could see the module,but the rear panel looks like it will have to come off to check it.
I have a dumb question,isnt there any warranty left on your KK?
richd is offline
post #9 of 15 Old 08-22-2010, 10:18 PM Thread Starter
mai-ling
2008 KK Liberty
the car responds when he hits the window open on the key by blinking its lights.
i guess i'll have to call the dealership to find out what they
have as far as a replacement module or something.
can't find much of anything online except that its seems to be a common issue.
www.mai-ling.net
mai-ling is offline
post #10 of 15 Old 08-23-2010, 09:46 AM Thread Starter
mai-ling
2008 KK Liberty
No warranty as far as we read since we are 2nd owners of vehicle.
Yeah you have take off the panel or pull back on it to even get to the latch.
OK here's a thought.
I picked a parts guy brain.
But I want a 2nd opinion.
Rchrd you mentioned on the odometer that when the window is open it say's window in the odemeter.
where our say's gate.
the guy mentioned that the actual gate door latch has a sensor that communicates to the window
latch and could be an issue?
before i go out and spend $66 on a part I want to make sure.
what do you think?
www.mai-ling.net
mai-ling is offline
post #11 of 15 Old 08-23-2010, 12:46 PM
richd
2008 KK Liberty
what do you think?
First about the warranty,if its used and you have under 36k on your KK,you can transfer the remaining warranty to you.On the gate door latch,thats where I was getting confused,because if it was the window it would say glass,if it says gate,then it would be a problem with the gate sensor.
richd is offline
post #12 of 15 Old 08-23-2010, 12:52 PM Thread Starter
mai-ling
2008 KK Liberty
Well we took a chance and bought the actual latch and just replaced it.
and guess what!?
it actually worked.
thank goodness.
thanks for your help richd.
www.mai-ling.net
mai-ling is offline
post #13 of 15 Old 08-23-2010, 12:53 PM
richd
2008 KK Liberty
and guess what!?
it actually worked.
thank goodness.
Im glad to hear that,and no problem with helping out.Are you going to check on the warranty?
richd is offline
post #14 of 15 Old 08-23-2010, 12:57 PM Thread Starter
mai-ling
2008 KK Liberty
we are definitly passed the 36k warranty.
My jeep has 59K and his 66K.
www.mai-ling.net
mai-ling is offline
post #15 of 15 Old 08-23-2010, 12:59 PM
richd
2008 KK Liberty
Ok I was just checking to make sure.Good Luck with both of them.
richd is offline
2009 Rear Window Leak spolebitski KK Liberty Forum 46 11-06-2013 10:42 AM
2008 Liberty Skyslider Issues JFK2218 KK Liberty Forum 39 04-05-2012 12:31 PM
2009 Jeep Liberty Issues JBWrangler2000 KK Liberty Forum 10 09-29-2010 10:55 AM
ZJ guy needs KK power window help rooster51 KK Liberty Forum 2 06-15-2010 09:20 PM
SkySlider - any issues YellowDuck KK Liberty Forum 21 05-18-2010 03:55 PM
