Liftgate issue. - JeepForum.com
post #1 of 5 Old 04-28-2013, 04:07 PM Thread Starter
skate6devil6six
2011 KK Liberty
Liftgate issue.
Trying to get to the wiper motor on my 2011. Assuming you have to remove the interior panel of the lift gate. Was fooling with it, removed 2 bolts and it still didnt seem to budge. Is there a trick to getting this off, or am I just an idiot?
skate6devil6six is offline
post #2 of 5 Old 04-28-2013, 04:55 PM
AtTheHelm
Just pull firmly after those two bolts are out. There are a bunch of clips holding it on.
AtTheHelm is offline
post #3 of 5 Old 04-29-2013, 06:26 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
REAR WIPER MOTOR REMOVAL
Disconnect and isolate the battery negative cable.
Remove the rear wiper arm from the rear wiper motor output shaft.
NOTE: The output shaft bezel and grommet (1) does not have to be removed to remove the rear wiper motor from the liftgate.
Remove the trim panel from the liftgate inner panel (2).
Disconnect the wire harness connector from the rear wiper motor (2).
Remove the three screws (3) that secure the motor mounting bracket to the liftgate inner panel.
Remove the motor from the liftgate.
Remove the bezel and rubber grommet (1) on the outer liftgate panel from the output shaft clearance hole. Be certain to take proper precautions to protect the outer liftgate panel and its paint finish from damage during this procedure.
JeepCares is online now
post #4 of 5 Old 04-29-2013, 06:28 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
LIFTGATE PANEL REMOVAL
Remove two bolts (2) from the lower trim panel (3).
Using a trim stick C-4755 or equivalent, release the fasteners at all of the locations around the trim panel (3).
Lift the trim panel (3) from the lift gate (1).
post #5 of 5 Old 04-30-2013, 01:59 AM
Drednot
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
