Liberty KK 08 tranny problem - JeepForum.com
post #1 of 4 Old 05-20-2011, 01:29 PM Thread Starter
Miguelacho
2008 KK Liberty
After a long drive, 300 miles, and after resting overnight, I started my truck normally, and when set to D, she moved roughly like doing small jumps. I hauled her to the dealer and said that a need to replace the automatic transmission, it is 4x4. After a brief discussion, I drove her again along with the dealer tech, and rode smooth without any noise or jump. After driving through a climbing road, going downhiil, I felt a bang in the transmission, and again to the dealer, no code in the scanner and no lights in the panel. The dealer tech response was the same as before, need a new tranny. Any comments? The truck has 25 K.
Miguelacho is offline
post #2 of 4 Old 05-20-2011, 01:37 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
First off, Welcome!! There are several TSBs in the TSB section that may help with the transmission shudder. Bring these up to the dealer as im sure they have heard of this problem.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 4 Old 05-20-2011, 04:29 PM Thread Starter
Miguelacho
2008 KK Liberty
Thanks for the info. I have downloaded 3 TSBs related to lib transmission shrudder and hope to get the problem solved at dealer shop.
post #4 of 4 Old 05-20-2011, 07:44 PM
VMF
2008 KK Liberty
if you are talking about it driving in lil jerks while engine is cold and when you slighlty press the brake pedal while gas pedal is depressed then its normal
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
Liberty 2008 - rubber around the shaft - problem langus KK Liberty Forum 5 10-22-2013 09:52 PM
What Liberty to get? wwessels KK Liberty Forum 10 05-01-2011 07:40 PM
Getting rid of my liberty... JFD140 KK Liberty Forum 2 12-09-2010 04:06 AM
5W-40 on Liberty KK 3.7 nkanakakis KK Liberty Forum 6 11-02-2010 01:35 PM
Should I get a Liberty? kinsale KK Liberty Forum 13 10-31-2010 05:49 AM
