Liberty Differential Fluid Change - Page 2 - JeepForum.com
post #16 of 24 Old 02-12-2011, 12:11 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Originally Posted by VMF View Post
did you change it in ur tcase urself?
do you command track or selec trac?
The drain plug and fill plug will be the same for those transfer cases.
The Plug, closes to the "ground", is the Drain Plug.
The plug, furthest away from the "ground", is the fill plug.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #17 of 24 Old 02-12-2011, 12:23 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Transfer Case: MP 1522 Command-TracŪ
Availability Standard on 4WD models
Type Part-time, electronic shift
Operating Ranges: 2WD, 4WD Lock, 4WD Low, Neutral
Low Range Ratio: 2.72:1
Transfer Case: MP 3022 SELEC-Trac IIŪ
Availability Optional all 4WD models
Type Full-time active, electronic shift
Operating Ranges 2WD, 4WD Auto, 4WD Low, Neutral
Torque Split, F/R 42/58
2008 Sport Liberty
post #18 of 24 Old 02-12-2011, 03:03 PM
VMF
2008 KK Liberty
we got the selec trac one, its awesome, since my wife drives the liberty it is important for me to know she is safe n sound and can drive in 4x4 mode without messing up the tcase
im prolly gonna do the tcase next weekend along with the brakes, the squealer is almost touching the rotor in the back already.
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #19 of 24 Old 02-12-2011, 03:27 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Great! Have her watch this little 4x4 educational instructions ( click on NEXT to view its entirety)
http://www.jeep.com/en/4x4/how_syste.../selec_trac_2/
2008 Sport Liberty
post #20 of 24 Old 02-12-2011, 03:32 PM
VMF
2008 KK Liberty
thanx i explained it all to her already, she has been driving though all this snow we got in NYC the only drawback are the tires, they are no bueno in the snow anymore, gonna have to change it next winter in a meantime i just hope there is gonna b no more snow i had to resque liberty 2 times when it bottomed out on the snowpiles with the wrangler. i wish liberty had lockers and swaybar disconnect like the rubicon does.
2004 UCF31. Black
VMF is offline
post #21 of 24 Old 02-14-2011, 06:14 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Summit racing is selling a transmission filter and gasket for under $20
http://cgi.ebay.com/ebaymotors/Wix-5...item564258d515
2008 Sport Liberty
post #22 of 24 Old 07-29-2015, 07:20 PM
orionsbelt77
Ok, so far I have changed the rear diff on my '11 Libby by pulling the rubber plug and suctioning the old stuff out. Both my suction pump and my quart bottle refill pump are still working great at 15yrs old. I did my homework on gear lubes by downloading a white paper pdf from goodsenseoil.com. You will know just what a gear oil goes through as far as testing- much more extensive than I ever thought. They tested a dozen or so brands of gear lube and I was surprised that Royal Purple made a rather poor showing up against the completion. Amsoil edged out on top, but I went with Valvoline syn power as it passed all the tests and was one that was military grade rated and placed in the middle of the bunch and since it was so much cheaper to buy than many other synthetics and on sale to boot at 6.99 a quart, it won me over hands down. As far as I know I pulled out the factory stuff at 54,000 miles, as I bought this jeep used. I used 75-140 in the rear and I bought 75-90 for the front, as well as Valvoline full synthetic trans. case fluid that is rated for atf +4 . I took a quick look under the front and as near as I can tell there are both drain and fill plugs for both the front diff and the trans case. I plan on doing this maintenance more often than the last owner. It is fairly easy, and I can use a tested full synthetic for a price that suits my budget. Now if only my oil filter was as easy as these other things.
orionsbelt77 is offline
post #23 of 24 Old 07-30-2015, 11:22 PM
profdlp
2007 KJ Liberty
I did all those things a few months ago. Well worth the savings by doing it yourself.
profdlp is offline
post #24 of 24 Old 07-31-2015, 04:49 PM
tommudd
2004 KJ Liberty
I would never suck the oil out, better to remove the cover on the rear, clean it out good and then you know there are no major issues.
As far as what to use, dino works better at clinging to the gears than any synthetic does
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
08 KK Automatic Transmission fluid & Filter change without a dipstick mjcougler KK Liberty Forum 18 10-09-2012 11:00 AM
Spark Plugs Change 2008 Liberty Limited 3.7 Rambler1 KK Liberty Forum 9 04-26-2011 07:08 PM
How much mileage before oil change on a 2011 Jeep Liberty? JeepLiberty2011 KK Liberty Forum 11 02-02-2011 09:58 PM
Rear Differential Bolts Torque rgarnsey KK Liberty Forum 2 01-02-2011 06:02 PM
Getting rid of my liberty... JFD140 KK Liberty Forum 2 12-09-2010 04:06 AM
