Liberty Differential Fluid Change - JeepForum.com
post #1 of 24 Old 02-11-2011, 03:43 PM Thread Starter
SuperRliBerty
2008 KK Liberty
I will change my rear diff fluid soon. These are posted video on Diff fluid changes. Could not find any a 2008 liberty, but these are jeep diff and the procedure will be the same.
- I would loosen all bolts
- "Crack" an opening in the seal with a flat head screw driver.
- Let drain.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #2 of 24 Old 02-11-2011, 03:55 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Inspection..... very important
2008 Sport Liberty
post #3 of 24 Old 02-11-2011, 04:01 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Applying RTV sealant ..... Removed the old sealant off the diff and diff cover. Remember this is not a Liberty, so you will have to purchase a new fill plug.
2008 Sport Liberty
post #4 of 24 Old 02-11-2011, 04:14 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Fill with 75w 90 Diff fluid ..
2008 Sport Liberty
post #5 of 24 Old 02-11-2011, 04:20 PM Thread Starter
SuperRliBerty
2008 KK Liberty
This is another way to change the rear diff fluid. With this method you will be removing the fluid, but some old fluid will remain at the bottom of the diff. It is kinda half arsed but effective....
he front diff is replaced in his video.... It is a Jeep cherokee.
2008 Sport Liberty
post #6 of 24 Old 02-11-2011, 04:32 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Transfer case fluid change 2002 - 2007 JEEP LIBERTY
2008 Sport Liberty
post #7 of 24 Old 02-11-2011, 04:52 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Transmission fluid and filter change
2008 Sport Liberty
post #8 of 24 Old 02-11-2011, 09:35 PM
VMF
2008 KK Liberty
i recently did both axles myself, had the car on the ramps, first the front, then the rear, front was was pretty ez and took like 15 mins while the back one was a $%^ !!! removing the diff cover while the sway bar and the spare is there was not that ez, using dremel on the axle to remove old sealant and polish the surface was no ez task either, had to use the extension. oh and putting the cover back with the sealant on was like a friggin surgery next time im just gonna use the lil pump to suck all old oil out! oh and i didnt want to touch the tranny, especially with the warranty n such so i paid the dealer 300$ (happend today actually) and it shifts much better! well may b its all in me mind but i sure think its more smooth, and it kinda stopped kicking when i would let go of the gas pedal during slow acceleration. it only has 27k but decided to do it now anyway. tranny is one expensive piece of hardware!
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #9 of 24 Old 02-11-2011, 09:36 PM
VMF
2008 KK Liberty
i wonder if the tcase oil change procedure is the same, since KJ and KK tcases are different.
good find man, appreciate the info!
2004 UCF31. Black
VMF is offline
post #10 of 24 Old 02-12-2011, 11:12 AM Thread Starter
SuperRliBerty
2008 KK Liberty
Thats why I am a firm believer in replacing the TRANSFER CASE, TRANSMISSION and DIFFERENTIAL FLUIDS at every 30k miles Whether you drive it under severe conditions, like a grandmother or like you stole it.....
2008 Sport Liberty
post #11 of 24 Old 02-12-2011, 11:15 AM Thread Starter
SuperRliBerty
2008 KK Liberty
This method is essentially replacing the fluids without dropping the pan. He should stress in the filter the importance of changing the filter every 30k miles.
2008 Sport Liberty
post #12 of 24 Old 02-12-2011, 11:40 AM
VMF
2008 KK Liberty
did you change it in ur tcase urself?
do you command track or selec trac?
2004 UCF31. Black
VMF is offline
post #13 of 24 Old 02-12-2011, 11:45 AM
VMF
2008 KK Liberty
and wtf is that noise in the tcase video throughout the whole video?
2004 UCF31. Black
VMF is offline
post #14 of 24 Old 02-12-2011, 11:56 AM Thread Starter
SuperRliBerty
2008 KK Liberty
lol.... my son said it is sponge bob playing in the back ground. That guy also added audio effect to his video post
2008 Sport Liberty
post #15 of 24 Old 02-12-2011, 12:05 PM
VMF
2008 KK Liberty
*do you have i meant to say
some psychedelic stuff that spongebob is, i can tell u that for sure, cartoons in my childhood were umm, much less "acid trip" like
2004 UCF31. Black
VMF is offline
08 KK Automatic Transmission fluid & Filter change without a dipstick mjcougler KK Liberty Forum 18 10-09-2012 11:00 AM
Spark Plugs Change 2008 Liberty Limited 3.7 Rambler1 KK Liberty Forum 9 04-26-2011 07:08 PM
How much mileage before oil change on a 2011 Jeep Liberty? JeepLiberty2011 KK Liberty Forum 11 02-02-2011 09:58 PM
Rear Differential Bolts Torque rgarnsey KK Liberty Forum 2 01-02-2011 06:02 PM
Getting rid of my liberty... JFD140 KK Liberty Forum 2 12-09-2010 04:06 AM
