-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   Liberty Differential Fluid Change (http://www.jeepforum.com/forum/f292/liberty-differential-fluid-change-1166735/)
SuperRliBerty 02-11-2011 03:43 PM
I will change my rear diff fluid soon. These are posted video on Diff fluid changes. Could not find any a 2008 liberty, but these are jeep diff and the procedure will be the same.
- I would loosen all bolts
- "Crack" an opening in the seal with a flat head screw driver.
- Let drain.
SuperRliBerty 02-11-2011 03:55 PM
Inspection..... very important
SuperRliBerty 02-11-2011 04:01 PM
Applying RTV sealant ..... Removed the old sealant off the diff and diff cover. Remember this is not a Liberty, so you will have to purchase a new fill plug.
SuperRliBerty 02-11-2011 04:14 PM
Fill with 75w 90 Diff fluid ..
SuperRliBerty 02-11-2011 04:20 PM
This is another way to change the rear diff fluid. With this method you will be removing the fluid, but some old fluid will remain at the bottom of the diff. It is kinda half arsed but effective....
he front diff is replaced in his video.... It is a Jeep cherokee.
SuperRliBerty 02-11-2011 04:32 PM
Transfer case fluid change 2002 - 2007 JEEP LIBERTY
SuperRliBerty 02-11-2011 04:52 PM
Transmission fluid and filter change
VMF 02-11-2011 09:35 PM
i recently did both axles myself, had the car on the ramps, first the front, then the rear, front was was pretty ez and took like 15 mins while the back one was a $%^ !!! removing the diff cover while the sway bar and the spare is there was not that ez, using dremel on the axle to remove old sealant and polish the surface was no ez task either, had to use the extension. oh and putting the cover back with the sealant on was like a friggin surgery:) next time im just gonna use the lil pump to suck all old oil out! oh and i didnt want to touch the tranny, especially with the warranty n such so i paid the dealer 300$ (happend today actually) and it shifts much better! well may b its all in me mind but i sure think its more smooth, and it kinda stopped kicking when i would let go of the gas pedal during slow acceleration. it only has 27k but decided to do it now anyway. tranny is one expensive piece of hardware!
VMF 02-11-2011 09:36 PM
i wonder if the tcase oil change procedure is the same, since KJ and KK tcases are different.
good find man, appreciate the info!
SuperRliBerty 02-12-2011 11:12 AM
Thats why I am a firm believer in replacing the TRANSFER CASE, TRANSMISSION and DIFFERENTIAL FLUIDS at every 30k miles :thumbsup:Whether you drive it under severe conditions, like a grandmother or like you stole it.....
SuperRliBerty 02-12-2011 11:15 AM
This method is essentially replacing the fluids without dropping the pan. He should stress in the filter the importance of changing the filter every 30k miles.
VMF 02-12-2011 11:40 AM
did you change it in ur tcase urself?
do you command track or selec trac?
VMF 02-12-2011 11:45 AM
and wtf is that noise in the tcase video throughout the whole video?
SuperRliBerty 02-12-2011 11:56 AM
lol.... my son said it is sponge bob playing in the back ground. That guy also added audio effect to his video post
VMF 02-12-2011 12:05 PM
*do you have i meant to say
some psychedelic stuff that spongebob is, i can tell u that for sure, cartoons in my childhood were umm, much less "acid trip" like
The time now is 02:44 AM.
