Liberty 2008 - rubber around the shaft - problem - JeepForum.com
post #1 of 6 Old 09-02-2010, 05:50 AM Thread Starter
langus
I have a 2008 liberty, the rear drive shaft had a rubber boot around it which was broken a few days ago. I'm looking for that part here in Europe but no chance. Instead of that jeep sellers suggest me to buy a new shaft with rubber for 400 euro = $600
Is anybody who can give me some hint where can I buy new or used rubber in the US?
Thank you in advance
Martin
langus is offline
post #2 of 6 Old 09-02-2010, 06:44 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
I Checked the Official Parts Manual and it only list 2 parts, the Entire Drive Shaft and the Bolts that hold it to the Transfer Case and to the Rear Axle. So it appears that you will need to replace the entire Drive Shaft. I would check a junkyard first to see if you can just unbolt the Drive Shaft and it should just drop out. Should be real easy to do.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 6 Old 09-02-2010, 10:48 AM
tjkj2002
2002 KJ Liberty
The OEM rear driveshaft is not servicable so you must replace the whole driveshaft as one unit.Heck you can not replace the u-joints,you must replace the whole driveshaft if you get a bad u-joint.
And no it's not a bad design as almost every vehicle(not just Chrysler) made today have non-servicable driveshafts till you get into the 3/4+ trucks.
tjkj2002 is offline
post #4 of 6 Old 10-11-2011, 09:12 PM
Rooster2387
[B]I have your solution to the non replaceable rubber boot, I have spent 4 months on the phone with spicer a d I can get the boot for 20 bucks intact I bought 2. My skid plate took a hard hit and bit my boot if your interested in a part number let me know. I have the first two in the aftermarket world one is on my jeep now
Rooster2387 is offline
post #5 of 6 Old 10-17-2013, 02:10 PM
lmb203
help!
I need one of those rubber boots asap.
lmb203 is offline
post #6 of 6 Old 10-22-2013, 09:52 PM
Rooster2387
Its been a while, I will try to locate the part# it is for the boot only, no straps
2008 Liberty Headlight Adjustment sbougon KK Liberty Forum 10 12-03-2013 06:02 PM
2008 Liberty Skyslider Issues JFK2218 KK Liberty Forum 39 04-05-2012 11:31 AM
2008 Liberty mechanical fan noise JWMII KK Liberty Forum 2 11-21-2010 08:09 AM
Fuse problem in my 2008 KK....NOT! A RODENT! Huntyeraws KK Liberty Forum 12 07-14-2010 06:51 AM
2008 Sport Liberty squeling when turning amike_321 KK Liberty Forum 6 01-19-2010 06:53 AM
