-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   Liberty 2008 - rubber around the shaft - problem (http://www.jeepforum.com/forum/f292/liberty-2008-rubber-around-shaft-problem-1096910/)
langus 09-02-2010 06:50 AM
I have a 2008 liberty, the rear drive shaft had a rubber boot around it which was broken a few days ago. I'm looking for that part here in Europe but no chance. Instead of that jeep sellers suggest me to buy a new shaft with rubber for 400 euro = $600
Is anybody who can give me some hint where can I buy new or used rubber in the US?
Thank you in advance
Martin
http://tinyurl.com/34gucf6
Elt31987 09-02-2010 07:44 AM
I Checked the Official Parts Manual and it only list 2 parts, the Entire Drive Shaft and the Bolts that hold it to the Transfer Case and to the Rear Axle. So it appears that you will need to replace the entire Drive Shaft. I would check a junkyard first to see if you can just unbolt the Drive Shaft and it should just drop out. Should be real easy to do.
tjkj2002 09-02-2010 11:48 AM
The OEM rear driveshaft is not servicable so you must replace the whole driveshaft as one unit.Heck you can not replace the u-joints,you must replace the whole driveshaft if you get a bad u-joint.
And no it's not a bad design as almost every vehicle(not just Chrysler) made today have non-servicable driveshafts till you get into the 3/4+ trucks.
Rooster2387 10-11-2011 10:12 PM
[B]I have your solution to the non replaceable rubber boot, I have spent 4 months on the phone with spicer a d I can get the boot for 20 bucks intact I bought 2. My skid plate took a hard hit and bit my boot if your interested in a part number let me know. I have the first two in the aftermarket world one is on my jeep now
lmb203 10-17-2013 03:10 PM
help!
I need one of those rubber boots asap.
Rooster2387 10-22-2013 10:52 PM
Its been a while, I will try to locate the part# it is for the boot only, no straps
The time now is 02:25 AM.
