Leveling kit curiosity - JeepForum.com
post #1 of 9 Old 10-30-2013, 06:40 AM Thread Starter
davepesce
I have a 2010 kk and I have been wanting to put a lift on it but I am a broke college student and I don't see that kind of money coming in any time soon. I was wondering if a leveling kit for the kk was a possibility? Does anyone have anything good or bad to say about them?
davepesce is offline
post #2 of 9 Old 10-30-2013, 07:24 AM
huntb
2008 KK Liberty
If you just want to level out the front end, do a search for "clevis lift" and you should find what you're looking for
Here is a post with a couple links at the end. KK is same as KJ http://www.jeepforum.com/forum/f28/clevis-lift-447282/
huntb is offline
post #3 of 9 Old 10-30-2013, 08:43 AM
AtTheHelm
You could do a 3/8" clevis lift, add 1/4" top plates from jba and 4 rear spring isolators (2 per side) for a small cheap lift. You'll get about 1.25" in the front and 1/2" in the rear.
Be forewarned though, once you do that you'll just want more.
AtTheHelm is offline
post #4 of 9 Old 10-30-2013, 08:48 AM
tommudd
2004 KJ Liberty
If using 2 rear spring isolator's per side you'd get an inch lift
If you want it level I'd do the clevis and top plate , then one rear iso per side since they have a natural rake from the factory
also make sure you get an alignment after any type of lift in the front
JeepinByAl
Strut plates 27.95
Clevis is basically free
forget what the rear iso's are off the top of my head for a KK
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #5 of 9 Old 10-30-2013, 09:34 AM
Bmxer524
2011 KK Liberty
I think the isos are around $10-15
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
post #6 of 9 Old 10-30-2013, 10:35 PM Thread Starter
davepesce
Thanks guys, that was exactly what i had in mind. Additional question.
If i were to put on the clevis lift, strut plates, and the isos, is this going to put extra pressure on my springs and struts/shocks resulting in the replacement of these parts sooner??
post #7 of 9 Old 10-30-2013, 10:43 PM Thread Starter
davepesce
Additionally, i do a decent amount of off roading and have my occasional bottom outs, which is why im looking for the extra bit of lift. Is this something that would be worth while, or will it end up bighting me in the a** down the road??
post #8 of 9 Old 10-30-2013, 10:59 PM
tommudd
2004 KJ Liberty
Bottoming out is due to the weak springs on the KK. Fronts are only rated at 310 lb and by the time you get 50-60,000 miles most have already sagged about 1/2 to an inch . So weak springs and shocks will cause it.
Doing a clevis and top plate will give you more height but will not stop the bottoming out completely. May help some but.........
Only real cure is of course a full springs / shock replacement
MUDD'S MOTORSPORTS
tommudd is offline
post #9 of 9 Old 10-31-2013, 11:41 AM
Bmxer524
2011 KK Liberty
It shouldn't bite you. Honestly I run the OME 927 front springs, and 731 rear springs with Bilstein shocks. I also added the 3/8" clevis lift, 1/4" top plate, and then 2 extra rear isos to get a total of 3.5" or so. I think I might be a little higher, but I'm also not as heavy as some of the other Libertys and I'm still breaking everything in with about 2k miles or so on the lift.
So when you save up the extra money you can always upgrade and add in the springs and shocks combined with what you're buying. Just make sure that if you do end up eventually getting the springs, that you buy al's a-arms. It's highly recommended, and even with them I'm having a hard time aligning my front end(my KK was always hard though).
Bmxer524 is offline
