Largest tire for Stock KK Limited 18" - JeepForum.com
post #1 of 4 Old 10-11-2010, 10:56 AM Thread Starter
travelhawk
2008 KK Liberty
Largest tire for KK Limited - is 235/60 the max for R18 stock wheel?
My 2008 Liberty has original tires MTS P235/60 R18 -- so, pretty large already, 29.1 inch diameter according to tire size calculator.
I'd like to raise the rig a bit, mainly so it is better matched to the tow bar height of the motorhome it rides behind.
Right now the height difference is 6 inches, ideally it would be 2" or less, but 4" would be an improvement. So, the ultimate goal is to raise the Liberty at least 2" or more. Less than that doesn't help the problem.
Easiest is to buy larger tires -- if they fit. Anyone have an opinion or even better, direct experience? What is the max tires size that can fit -- note the 18" stock wheels?
And/or, I could lift the body a bit. What is recommended to do this, and what might it cost?
Again, the main goal is to raise the chassis height, with added clearance being a by-product. (Unlike my earlier GPW which I took anywhere/everywhere, this Liberty is limited to Jeep-grade "roads", not crawling.)
Thanks for your input.
travelhawk is offline
post #2 of 4 Old 10-25-2010, 02:06 PM
jerwhite
2008 KK Liberty
Wow. Seems to be the trend on this site. A lot of questions and very little answers. I have been researching this for two years. Still haven't found a definitive answer. I have switched moods to researching different rim/tire combos. Good hunting.
jerwhite is offline
post #3 of 4 Old 11-01-2010, 05:03 PM
DoubleK
2008 KK Liberty
i heard a couple of different things. i heard that with my KK, i can fit 265/70/r16 without a rub bc i also have a lift, but then again i've heard the opposite..... so idk about your size, heck idek about mine lol ill tell you how it goes when i get the lift and tires in
DoubleK is offline
post #4 of 4 Old 11-04-2010, 02:53 PM
ddmag52
2008 KK Liberty
I just had 245-60-18 tires put on so far no rub at all.
ddmag52 is offline
Largest tire for Stock KK Limited 17" drewkk KK Liberty Forum 4 12-15-2010 08:20 AM
KK Limited 17" Wheel Offset CajunPatriot KK Liberty Forum 0 09-01-2010 07:50 AM
Why is the Sport limited to only 3500lb tow capacity? KDOG2008 KK Liberty Forum 3 06-20-2010 06:18 PM
Price for 2010 Liberty Limited kinsale KK Liberty Forum 1 06-18-2010 05:20 PM
Liberty Limited Rear Air Vents? kinsale KK Liberty Forum 7 06-18-2010 02:35 AM
