KK Struts worn out @6000 miles ! - JeepForum.com
post #1 of 15 Old 09-02-2013, 09:35 PM Thread Starter
Katmandu
Our 2012 KK only has 6,000 miles on it and the front struts are SHOT!
This KK was bought brand new with 50 miles on it and never off-roaded, beat up on or driven hard on irregular pavement. It's been driven on flat highway about 90% of the mileage.
We have had a high speed vibration coming out of the front end for the past 4,000 miles or so. I've replaced the OEM POS Goodyear Fortera's with Michelin MXV and still the vibration persists. I even had the replacement Michelins replaced (under Warranty) for a new set of Michelin ICE2's. Vibration still there.
Hard to believe that the struts are shot after 6,000 miles.
I was going to take it to the Dealership but figured they would do crap since struts are a wear item.
We're saving up for some Bilsteins.
Anyone else's struts go bad prematurely ?
Katmandu is offline
post #2 of 15 Old 09-02-2013, 09:45 PM
tommudd
2004 KJ Liberty
replace the springs as well or you'll be right back needing new front shocks again.
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #3 of 15 Old 09-02-2013, 09:49 PM
tjkj2002
2002 KJ Liberty
And what makes you think it's the front shocks? Have you changed them to confirm they are bad? Many things can cause a high speed vib and the only thing you have seem to try is the tires.That is one of about 100 things that can cause your vib.
tjkj2002 is offline
post #4 of 15 Old 09-02-2013, 10:36 PM
Drednot
Has the alignment ever been checked?
What kind of wheels are you running?
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #5 of 15 Old 09-03-2013, 08:00 AM
huntb
2008 KK Liberty
Not struts. Shocks
huntb is offline
post #6 of 15 Old 09-03-2013, 05:40 PM
RB145
2014 WK
The Liberty has struts in the front and I really doubt this is the source of the problem. When do you get the vibration under what conditions?
RB145 is offline
post #7 of 15 Old 09-03-2013, 06:07 PM
tjkj2002
2002 KJ Liberty
Shocks not struts.
Struts takes place of the upper control arm and ball joint and has a intergrated bearing in the top plat so it can pivot since a strut directly bolts to the knuckle.The KK has a upper control arm with ball joint and uses coilover shocks.
tjkj2002 is offline
post #8 of 15 Old 09-03-2013, 10:02 PM
Poncherello
2010 KK Liberty
Hey Fellas,
A question: My Lib is approaching 60K, still have mighty Wrangler SRAs on it and stock rear shocks and springs. Took a peak underneath, lately my Lib is starting to feel like my grandfather's 74' Ford Grand Marquis lol. Not totally. Notice some oil on the outside of the shock. If you wouldn't mind taking a look and making an evaluation?
Thanks
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #9 of 15 Old 09-03-2013, 10:07 PM
tjkj2002
2002 KJ Liberty
Originally Posted by Poncherello View Post
Hey Fellas,
Thanks
Leaking,time to replace.Always replace in pairs so replace both rear even if the otherside looks fine as it's not far behind from failing also.
It is industry standard to replace shocks(and if you have struts) every 50k where they look good or not.Shocks and struts effect so much more then just the ride,they also have a direct effect on how the brakes work.
tjkj2002 is offline
post #10 of 15 Old 09-03-2013, 11:06 PM
Poncherello
2010 KK Liberty
Thanks TjKJ,
Was afraid of that. I am not looking at lifting more than 2" just improving the ride stability and hoping to go further then 58K on the next set of springs and shocks.
I know Gageraid speaks highly about OME springs and Shocks perhaps upper control arms, any of you other guys deal with Jeepin By Al's? I was thinking of giving them a call and was wondering too if they do installs too? If not, would need to find someone else also and alignment place as well.
post #11 of 15 Old 09-03-2013, 11:21 PM
tommudd
2004 KJ Liberty
Thanks TjKJ,
Lots of folks deal with JBA, at this time they do not have the space to do installs .
MUDD'S MOTORSPORTS
tommudd is offline
post #12 of 15 Old 09-04-2013, 01:18 AM
Bmxer524
2011 KK Liberty
Thanks TjKJ,
They had great customer service when I was ordering my parts. And OME is definitely recommended. I opted for Bilstein shocks though, so I can't comment on the OMEs. Honestly, installing the lift isn't hard. Took 3 or 4 hours(used it as a learning process for me since I wasn't too sure about suspensions) for mine, but we also had a friend's shop and put the truck on a lift. Not sure how long a driveway instal would really be. And firestone did my alignment.
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
post #13 of 15 Old 09-04-2013, 07:12 AM
tommudd
2004 KJ Liberty
If going OME I'd go OME shocks
Bilstein are good no doubt but OME springs and OME shocks are matched
Also Ironman are good set up with the front shocks being just a little longer than the OMEs , Bilstein or stock
Driveway install less than 3 hours easy
MUDD'S MOTORSPORTS
tommudd is offline
post #14 of 15 Old 09-04-2013, 08:35 AM
MtBJet
This is the setup I have... OME HDs/Ironman. Would recommend pretty highly.
MtBJet is offline
post #15 of 15 Old 09-04-2013, 08:40 AM
huntb
2008 KK Liberty
Only problem is that the rear Ironman shocks are not long enough for anything over a 1.5" lift. I talked to Marlin at JBA and he said they are getting new, longer Ironman rear shocks. I'll email him again and see if he's received them or not
huntb is offline
