-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   KK Recall (http://www.jeepforum.com/forum/f292/kk-recall-1700146/)
jeepster1947 10-19-2013 08:19 AM
KK Recall
Just received a safety recall on my '12 KK Limited. Something about the active head restraint not working right in a rear end collision. Didn't know I had that.
Stang977 10-19-2013 10:46 AM
Yes. Nice feature.
Don't try to take the headrest out of the seat without the proper procedure. It may deploy. Almost found out the hard way when putting my grab handles on!
JeepCares 10-21-2013 08:04 AM
Here's some information about AHR:
Supplemental Active Head Restraints (AHR)
These head restraints are passive, deployable components,
and vehicles with this equipment cannot be readily
identified by any markings, only through visual inspection
of the head restraint. The head restraint will be split
in two halves, with the front half being soft foam and
trim, the back half being decorative plastic.
How The Active Head Restraints (AHR) Work
The Occupant Restraint Controller (ORC) determines
whether the severity, or type of rear impact will require
the Active Head Restraints (AHR) to deploy. If a rear
impact requires deployment, both the driver and front
passenger seat AHRs will be deployed.
When AHRs deploy during a rear impact, the front half
of the head restraint extends forward to minimize the gap
between the back of the occupant’s head and the AHR.
This system is designed to help prevent or reduce the
extent of injuries to the driver and front passenger in
certain types of rear impacts.
NOTE: The Active Head Restraints (AHR) may or may
not deploy in the event of a front or side impact.
However if during a front impact, a secondary rear
impact occurs, the AHR may deploy based on the severity
and type of the impact.
Additional information can be found in the Owner Manual available here.
jeepster1947 10-21-2013 06:41 PM
Thanks so much for the data. Very informative.
Drednot 10-22-2013 08:34 PM
Here's a good article about it with pics
http://www.wk2jeeps.com/wk2_active_restraints.htm
jumpthis 10-29-2013 08:24 PM
I never received the recall letter at all on this issue. However, my airbag light has been on for the past two days. Finally had a chance to diagnose it. Ran it through the scanner code reading: B2208 Active: Occupant Restraint Controller Internal 2 .. We tried to flash it but didnt work so the control module has to be replaced- i work for a dealership (subaru) and Jeep can't get me in until mid-november in order to get a loaner car was not happy to hear about that at all :(
jeepster1947 10-31-2013 05:23 AM
Jumpthis...could be your KK is not equipped with this device.
The time now is 04:27 AM.
