KK Lift: Which is best? - Page 4 - JeepForum.com
post #46 of 61 Old 01-19-2013, 06:33 AM
jonrjen
2011 KK Liberty
FWIW: I have read a number of LIFT POST in the past, but there has been more information offered here to the Newbies to the lift scene than any other I have come across and read. Many post tend to focus on one manufactures lift..period. Many post assume that everyone knows the basics of a lift and the differences between them. This post has helped to clear the brain clutter guessing of what differences there are between various lifts.
So Thank you everyone for your time and knowledge you have and care to continue sharing!!
"If you have a difficult job to do....Give it to a lazy man....He'll find the easy way to do it."
jonrjen is offline
post #47 of 61 Old 01-19-2013, 09:21 AM
Drednot
Originally Posted by jonrjen View Post
Drednot:
It looks as though your KK still retains that factory front end lower than the rear stance..is this true? Can the front end on the JBA be cranked up to level out the KK so that is sits level?Yes, I have the front lower . The adjust-a-struts in front adjust to your liking. My kit was the 2.5" but the rear springs gave an even 3" so I cranked the fronts up till they were 3" higher. That way it retains the factory rake (+/-)
If so would you have a photo of the level stance you could post?
What are your impressions of the ride now that the JBA is installed? How many miles have you driven with it installed? Huge improvement in ride and handling over stock. I have around 4000 miles on it and the outstanding on road ride is worth the extra money in my opinion. Off road its been flawless but I haven't taken the time to abuse it like some folks do.
If you don't mind my asking, where did you locate the tail light guards?E-bay
And Last comment...Great looking KK!!!Thanks!!!
I appreciate the feedback. I was totaly sold on the JBA Silver package, but then the Mudd lift and pocketing a grand was looking very tempting.
Hope this helps
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #48 of 61 Old 01-19-2013, 02:33 PM
rescue575
2011 KK Liberty
Hey Tom, no repositioning of the brake lines or anything would be required with your 3.5" kit?
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #49 of 61 Old 01-19-2013, 03:53 PM
_benjammin
2012 KK Liberty
Me too.
Still thinking silver though...hopefully skids and rock rails in the next year so I like the ability to adjust.
_benjammin is offline
post #50 of 61 Old 01-19-2013, 07:56 PM
Drednot
Here's a few more pics.
You can see where the CV joints just about bind at full droop. There is also a fraction of an inch of clearance between the inner boot and the clevis .
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #51 of 61 Old 03-13-2013, 07:55 PM Thread Starter
Shannon-8
2010 KK Liberty
Put TOMMUDD'S ECONO 3.5" LIFT KIT on my 2010 KK Renegade today. The lift was not a full 3.5". Also, I now need to replace the stock panhard bar with an adjustable one because my rear tires aren't center anymore. And the rear support arms are now too short so I need to get new ones as well. Everything else looks good though.
Shannon-8 is offline
post #52 of 61 Old 03-13-2013, 08:16 PM
AtTheHelm
If by rear support arms you mean control arms there aren't any available unless you go custom for big $$. You would probably need to get a longer driveshaft if you installed longer arms too.
What are the measurements from the center of the wheels to the bottom of the flares?
AtTheHelm is offline
post #53 of 61 Old 03-13-2013, 11:55 PM
TIJKK1220
2008 KK Liberty
I wish the underbelly of my KK looked that clean.
My 08 looks like it's taken a beating
TIJKK1220 is offline
post #54 of 61 Old 03-20-2013, 04:59 PM Thread Starter
Shannon-8
2010 KK Liberty
My 2010 KK Renegade is lifted and has bigger tires! But now my ESP/BAS light is on. Any suggestions?
post #55 of 61 Old 03-21-2013, 08:06 AM
huntb
2008 KK Liberty
The fuse box comes out when you install the lift (not sure if you installed it yourself) but you should check to make sure all of the connections got made when the box was reinstalled. I believe that there were 4 connectors if my memory serves me correctly.
huntb is offline
post #56 of 61 Old 03-24-2013, 12:52 PM
27tubguy
2008 KK Liberty
I did
Did you get your updated parts installed? If so how did that go? Any latest and greatest photos with the front cranked up to a level stance on the KK?
Would love to see the photos if you have any more.
As for the difference in the Rock vs JBA, I understand that $1K difference. I guess you need to keep in mind that your dealing with the owner developer who has a reputation he has built and fully intends to protect. Questions or help is only a phone call away.
And it is fully adjustable as to height/ride in the front.
Still a $1K is a $1K and it is your choice where to put it.
I got the roller bushing and o rings for the rear bilstiens and it makes the fit perfectly no banging around, quiet great ride, killer flex. 5k miles on the lift so far, not one problem.
Richie from Boston
27tubguy is offline
post #57 of 61 Old 03-25-2013, 06:55 AM
_benjammin
2012 KK Liberty
I have nothing to compare to but I am so happy with my JBA Silver.
post #58 of 61 Old 03-30-2013, 09:31 PM Thread Starter
Shannon-8
2010 KK Liberty
Tom's Lift and 31s
post #59 of 61 Old 04-01-2013, 12:15 PM
shawnicles
Originally Posted by tjkj2002 View Post
Good luck,you will need it.You may get your parts and if you do they may fit.If you have any issues good luck getting any help from Glen.
I ended up going with the RRO deluxe kit as well before I joined this forum and when I got the lift and installed it I ran into problems. Despite what everyone says on here, I have had great service from everyone at RRO. With the help from my shop they spent a lot of time figuring out what the problem was, and then they spent no time doing the right thing and shipped me out new parts right away.
So yes, I did order RRO and there was an issue but at the end of the day they took ownership and kept me happy. Maybe I wouldn't have had that issue with the JBA stuff or maybe I would have. Who knows, but I am definitely an advocate for the service after purchase from RRO.
shawnicles is offline
post #60 of 61 Old 04-21-2013, 06:31 PM
ghostimpala
shawnicles - I believe your kit is a 3'' lift with "everything????" required to do the lift. Did you have to modify anything else and or buy additional items (drive shaft, break lines, gears, etc.)? What size tires do you have? Thanks.
ghostimpala is offline
