KK Liberty max tire size with no rub - Page 3 - JeepForum.com
 2Likes
post #31 of 38 Old 01-13-2010, 11:57 AM
09_Silver
2011 KK Liberty
Can someone explain exactly what the differences are between the Daystar lift kit (or similar) and a "full spring kit"? Thanks
'11 Liberty Jet Sport - 4x4
09_Silver is offline
post #32 of 38 Old 01-13-2010, 12:08 PM
tommudd
2004 KJ Liberty
Brief example
Full springs kit is when you basically remove you suspension ( springs and shocks) and replace them with upgraded ones for a better ride, better handling etc. For example stock springs ( using a KJ ) are rated at between 300-320 lbs in the front, upgrading to say OME heavy Duty 927s with 400 lb spring rate it rides better etc, thus upgrading same way with shocks
Spacer kits like the daystar use a puck that you install in with the stock spring to gain height but does nothing for better ride etc, also will over time also make the springs sag quicker due to always having them compressed more than normal
tommudd is offline
post #33 of 38 Old 01-14-2010, 12:15 AM
09_Silver
2011 KK Liberty
Cool. Thanks. So do you get a better ride due to higher quality springs and shocks? Seems like springs with a higher spring rate would give you a stiffer, rough ride.
post #34 of 38 Old 01-14-2010, 01:06 AM
tommudd
2004 KJ Liberty
You get a firmer more controlled ride I think
Example on set of railroad tracks that I used to cross daily, before I lifted I would have to slow down to 30/35 to cross due to it hitting bumpstops and bouncing all over , after I lifted I could run across them at 55/60 no problem. Also stock springs are sagging at 30,000 or so, I just switched out my OME heavy duty springs with 100,000 miles on them.
tommudd is offline
post #35 of 38 Old 01-15-2010, 05:37 PM
09_Silver
2011 KK Liberty
That sounds like exactly what I want. Where do you recommend getting the OME kit from? And would I need OME springs and struts?
Ooh....just found this:
http://www.rocky-road.com/kkrockfather.html
I think I need to save up for the deluxe kit!
post #36 of 38 Old 05-03-2017, 09:18 PM
Absargent981
Which skyjacker rear shock did you go with?
Absargent981 is offline
post #37 of 38 Old 05-04-2017, 05:49 AM
lfhoward
2008 KK Liberty
The last post was from 2010, so it's doubtful you'll get an answer.
Neither Skyjacker nor Rocky Road Outfitters gets good reviews from KK owners on here or over at LostJeeps.
Stick with OME springs / Bilstein shocks and you will have a good 2.5 inch kit that lasts and rides well. Or go all the way and get JBA. Do some more reading before deciding on RRO.
Steve40th likes this.
2008 Liberty Sport 4x4 Automatic
lfhoward is online now
post #38 of 38 Old 05-05-2017, 03:52 PM
tommudd
2004 KJ Liberty
Do not use Skyjunkers
Either OME or Bilstein shocks with good OME springs from www.jeepinbyal.com
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
snorkel for liberty kk david1980 KK Liberty Forum 6 05-03-2013 08:28 AM
Liberty Gas Mileage jeepkid60 KK Liberty Forum 63 11-29-2010 01:12 PM
08 Liberty Sirius Install Kit dnocito KK Liberty Forum 2 10-30-2010 05:14 PM
15's on an 08 Liberty>?? CoachRamirez KK Liberty Forum 2 02-06-2010 10:28 AM
Liberty or Patriot better off road? diver110 KK Liberty Forum 4 12-17-2009 05:28 PM
