KK Liberty max tire size with no rub - Page 2 - JeepForum.com
post #16 of 35 Old 12-01-2009, 04:21 PM
Ogr8itsOGRE
2008 KK Liberty
Hopefully my following question doesnt become my following dilema lol....
palaz... did you have a lift on with the 1" wheel spacer's on?
i have the 2.5" skyjacker spacers and i picked up a set of wheels. The rear wheels already have an offset bringing the wheel out 1.25 inches.
I was planning on adding spacers ontop of that...is this possible???
as it is 2.5" above stock......
i love that bad @$$ wide jeep look lol
I have 2" spacers for the front and 1.25" spacers for the rear (making the rear offset 2.5")
Any help would be greatttt
-The OGRE-
Ogr8itsOGRE is offline
post #17 of 35 Old 12-02-2009, 12:10 AM
palaz
2008 KK Liberty
Yes I had a 1,5' lift.
However it depends on the tyre size. If you stay close to the stock size there shuld not be any problem. If you go higher like mine 245/75-16 (30,5') then the wheel spacers tend to create more wheel rubbing.
LIBERTY KK 2.8 CRD OME 2''
palaz is offline
post #18 of 35 Old 12-02-2009, 06:47 AM
Ogr8itsOGRE
2008 KK Liberty
Hmmm is it possible that the extra inch of lift I have might allow for both the spacers and the tires? I'm goin w the 245/75-16's eitherway so I guess we will just see if these wheel spacers are now a set of paperweigHts for me lol. Any other info is more then welcome... Thanks fellas
-The OGRE-
post #19 of 35 Old 12-02-2009, 06:52 AM
Ogr8itsOGRE
2008 KK Liberty
Also, was your rubbing only in the rear? Also what would be the tire size between stock and 245/75/16? Thanks
-The OGRE-
post #20 of 35 Old 12-02-2009, 08:37 AM
palaz
2008 KK Liberty
My original tyres were 235/65-17 (i.e 29').
Then I got a set of 235/70-17 (i.e. 30')
Then I got another set of 245/75-16 (i.e. 30,5')
Of the above only the original ones did not rub with the 1' wheel spacers.
The other two were rubbing (only at the rear) and after removing the spacers there is zero rubbing.
All this with 1,5' suspension lift.
palaz is offline
post #21 of 35 Old 12-02-2009, 09:30 AM
Ogr8itsOGRE
2008 KK Liberty
Gotcha... Welll my problem is the rims I have already have an offset that will bring it out 1.25" in the rear so essentially I'm locked into having stock sized tires
Do you think the rubbing could be resolved by removing some of the wheel well lining or something? I haven't got a chance to look at the wheel well as I'm not at my car. I just realllly wanna have big tires and be lifted with spacers on. Its all I want lol
Thanks for your help
-The OGRE-
post #22 of 35 Old 12-04-2009, 10:28 AM
osargd
2004 KJ Liberty
Daystar - Driven by Design
This thread seemed like a good place to post this question... (04' KJ - Stock)
Id like to get a more expensive lift (Frankenlift or Old Man Emu) but my wallet said no... I'm not usually on serious offroad trails, more like 4 wheelin on the beach and on some trails... will this Daystar do the trick or is it junk? I've wasted money before on Junk, not looking to do again!
-O|||||||O-
GDO - 04' Liberty
Last edited by osargd; 12-04-2009 at 10:29 AM. Reason: forgot to mention my make/yr
osargd is offline
post #23 of 35 Old 01-11-2010, 09:14 AM
Tarman
Originally Posted by palaz View Post
Oh no, no! I was referring to ljs1 comment on wheel spacers.
I tried to put on the 1' wheel spacers which I removed from my old KJ but this proved to make things worse with rubbing (in the rear).
So I meant wheel spacers.
How did wheel spacers make it rub in the rear? I can't see it.
Tarman is offline
post #24 of 35 Old 01-11-2010, 09:55 AM
palaz
2008 KK Liberty
Ok, have alook at the following picture, especially the one at the right.
Now imagine this situation with an additional 1' spacer.
Is it clear what I mean now? The upper part of the tire is rubbing against the fender flare.
palaz is offline
post #25 of 35 Old 01-11-2010, 10:02 AM
Ogr8itsOGRE
2008 KK Liberty
I currently have the 1" spacers with 245/75/16 and 2.5" lift all installed. And although I experience rubbing at the max compression I never have issues in daily driving... Looks great tho and if I wanna do somE bad *** off roading I can just take em off...
-The OGRE-
post #26 of 35 Old 01-11-2010, 10:05 AM
palaz
2008 KK Liberty
This is correct. You will never notice anything in normal driving.
And even at full flex, the rubbing is minor.
palaz is offline
post #27 of 35 Old 01-11-2010, 10:16 AM
Ogr8itsOGRE
2008 KK Liberty
Ill be uploading pics of my beast shortly...I'm finally done modding it (for a little while) lol...
-The OGRE-
post #28 of 35 Old 01-11-2010, 10:31 AM
palaz
2008 KK Liberty
So let me tell you what minor mods I have done in order to avoid shredding my bumpers (rear one already torn)
In front I installed a tailor-made, 6mm thick, Alu skid plate, which also replaces the decorative nikel piece, as it folds around the bottom part of the bumper. It is certainly understood that the little black spoiler has been removed already long time ago.
In the rear, like I said, I had already torn my bumper in a very steep climb I attemted. I decided not to fix it but rather keep until it falls apart by itself. So I decided to remove a small part at the bottom which seems to act as an anchor every time I deal with a steep slope. Needless to say that the metal traverse part under the bumber has been removed too...
palaz is offline
post #29 of 35 Old 01-11-2010, 10:55 AM
Tarman
Ooooh I see. Thank you for clarifying.
Tarman is offline
post #30 of 35 Old 01-11-2010, 05:44 PM
tommudd
2004 KJ Liberty
Depends on what you want
if its a good ride, better handling easier to control on all surfaces then you need to do a full spring lift. With an 04 you have to have over 30-35,000 miles and with that the springs have already sagged causing a worse ride and handling. A spacer lift will only make the springs sag faster . Save up the money over a couple of months and do it right one time. Have heard of way too many people who think they can do it cheap and then 3 months later redoing their lift with a full spring. With your 04 as well even if you did go Daystar you would need to replace the front and rear shocks and also install bumpstops. With the price of the above you're only 150/175 less than a full spring kit
tommudd is offline
snorkel for liberty kk david1980 KK Liberty Forum 6 05-03-2013 09:28 AM
Liberty Gas Mileage jeepkid60 KK Liberty Forum 63 11-29-2010 02:12 PM
08 Liberty Sirius Install Kit dnocito KK Liberty Forum 2 10-30-2010 06:14 PM
15's on an 08 Liberty>?? CoachRamirez KK Liberty Forum 2 02-06-2010 11:28 AM
Liberty or Patriot better off road? diver110 KK Liberty Forum 4 12-17-2009 06:28 PM
