-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   KK Liberty 2012- thumping noises coming from tire area (http://www.jeepforum.com/forum/f292/kk-liberty-2012-thumping-noises-coming-tire-area-1426410/)
kellybelly28 10-11-2012 10:47 AM
Hi everyone,
I just got a 2012 Jeep Liberty(less than a month ago) and noticed that when I accelerate past 40 mph that a loud noise comes from my right front or back tire. It sounds like my tire is about to go flat... that thumping noise right before a tire dies out. I checked my tire pressure on my tires and they all are fine. I'm not sure what the problem can be? Possibly metal hitting my tire?
Any ideas?
Thanks.
Drednot 10-11-2012 10:53 AM
Lost wheel weight combined with the poorly damped factory shock.
Does it do it all the time? or only once in a while?
Does it go away when you get going faster or does it get progressively worse with speed?
bagwell 10-11-2012 11:05 AM
1. take it to a tire shop and let them check your tires for defects.
2. take it to the dealer and tell them the problem and fix it.
JeepCares 10-11-2012 12:54 PM
X2 ^^
although, I'd probably try the dealer first
kellybelly28 10-11-2012 01:00 PM
Thanks for responding. It only does it when I accelerate. It doesn't do it when I break or slow down.
It goes away once I hit around 55-60 mph. Loudest around 35-50.
The dealer is most likely not going to find what the problem is and that's what I'm worried about. It doesn't sound like a stone is in my tire. Def. not a clicking noise, but more of a thump. I checked the tires and they look fine.
Drednot 10-12-2012 01:56 AM
If it does it all the time, just insist on taking them for a spin and demonstrate the condition.
When it happens, do you only hear it, or can you feel it through the steering wheel, your feet, or your seat?
Is it a loud , insistant, solid hit, or soft, muffled?
tbenson 10-14-2012 09:45 AM
My 2011 has/had, as you describe,this same issue from new...very annoying!
I have blamed it on junk Goodyear tires, maybe I should get mine looked at before the warranty runs out.
mbrooks1982 11-16-2012 08:29 AM
My 2012 does the same thing. Dealer can't figure out the problem, even after I took them for a ride. Sounds like a rock is in the tire and is loudest around 35-45. My diagnosis unfortunately is leading me to the junk "Oneyear" tires as well. Can't wait to replace them.
jonrjen 11-17-2012 04:34 AM
OEM tire replacement should be darn near mandatory on the Liberty. The factory tires are crap and built for one purpose because they are cheap and serve a temporary need. They flex, allow for little traction, are loud and border on the line of be dangerous. Don't try a highway speed evasive maneuver on the stock tires you could end up in a world of hurt.
jonrjen 11-17-2012 04:38 AM
Another train of thought maybe that when the tires were mounted to the wheel, someone along the production process thought it would be cute to drop something into the tire cavity (thinking wheel weight, valve stem) just for giggles and grins to drive the new owner nuts?
georgejeri 11-26-2012 03:41 PM
Just a thought to try and eliminate things. How about a tire rotation to see if that changes anything? See if the noise "moves." I might be tempted to get some help and go for a ride with the windows down with family/friends listening/hanging out the windows. Might help isolate the noise area.
kellybelly28 12-20-2012 07:58 AM
Thank you everyone for your response. Sorry for the total delay in response on my end. I took it to the dealer for a test ride for 45 minutes- drove all around town and of course he didn't hear the sound. The second we drive away the clunking thumping noise occurred again. I became frustrated and asked the manager if they were having issues with this model and year concerning the thumping sounds in the tire and they said yes. I'm not sure why they wouldn't recall the tires if this seems to be a constant issue!
They cannot figure out where the sound is coming from which leads me to a great amount of frustration. Has anyone replaced the stock tires and had success with not hearing the noise again?
I noticed that the sounds only occur between speeds 35-50 and get louder when I decrease rpm after accelerating. My tire psi also decreases on the sides where the sounds are coming from(right both tires). The sound is definitely heard right around the tire area and has been heard by my entire family. The noise level is getting louder and the duration of the sound is also increasing. I feel slight vibration in the steering wheel but feel the worse vibration in my gas pedal when the thumping sound occurs.
If anyone else has suggestions, please feel free to throw them at me since the dealer has no idea how to fix this issue.
swamppro 12-21-2012 06:42 PM
Check and see if your front wheels are hot after. Mine was doing the same thing and now my brake calipers were sticking and fried the pads and rotors. Mechanic told me this was not the first he has seen.
Jason0319 02-16-2013 05:57 PM
My 2012 Jeep Liberty has also done this since we bought it new. It has been to three dealers and they can not find the problem. They say it's not "safety related". I have had the tires rotated and the noise still seemed to come from the RF area. I can really feel mine in the floorboards, esp the passenger side. RF wheel hub was also replaced by the dealer but that didn't help. Let me know if you find anything out as its very frustrating!!
Rbatez 06-14-2015 02:53 PM
same problem
Originally Posted by kellybelly28 (Post 14286375)
Hi everyone,
Any ideas?
Thanks.
Hello,
I also have the same problem with my jeep liberty 05. Its been a few years now that I have been replacing stock parts to try and get rid of this constant annoying tire thumping. I bought my jeep used with a 1.5 leveling kit. My biggest mistake. Well so far i have replaced my control Arm with ball joints,Breaks, Tie rod outer,sway link bar, new tires, rims had it balanced. After the tires it seemed to have gone away or so i thought! well a couple weeks ago i had my coil spring and strut replaced because thumping tires wasn't the only problem. Every time i would hid a pot hole or man hole in the street the right tire would hit hard and i could stand it. Coil springs CAN lose the spring firmness. One problem gone thankfully. DAM Tire thumping came back! I Read it could be that the transfer case skid plate my need to be dropped to balance the tires out. I dont know any more to be honest Mechanics dont know jack either. I replaced all those parts because they said that was causing the problem. i just bought a axle shaft, right after I changed my shocks. I thats probly not going to fix it either.
The time now is 12:03 AM.
