KK CB Install: Write up - Page 3 - JeepForum.com
post #31 of 104 Old 10-13-2012, 12:06 PM
Sagerist
Sagerist's Avatar
Good luck with your install. Its been fun running around listening to all them truckers jabber on. although i have been hearing a lot of some schmuck hi-jacking the standard trucker channel and it couldnt be anymore annoying. I did have to pull my CB out as my Fire Chief got me setup with one of the VHF/UHF Mobile Radios since I am about to become a lieutenant on the fire dept im on. Jeep looks insane with three antennas coming off her!!
Colorado Jeep Club Member #286
89 YJ 2.5L
OME 36R's, Bilstein 5100's, Bserk 5/8" shackles, 33x10.5 BFG's on 15x8
09 KK Sport 4X4
235/75/16 GY Slnt Armor
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline
post #32 of 104 Old 12-18-2012, 08:06 PM
rescue575
2011 KK Liberty
How did you guys ground the antenna??? Did you sand down the body at all to get bare metal?
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #33 of 104 Old 12-19-2012, 03:07 PM
Sagerist
Sagerist's Avatar
You don't need to. Worse of all, if you ground it wrong, the signal gets re-routed and doesn't even get out. This happened on my Buddies JK. We pulled the ground and lo-and-behold the CB worked perfectly.
The most important thing you can do is tune the antenna. If you key the Mic before the antenna is tuned you can blow the radio. Unfortunately, i did this on my UHF radio and had to have it replaced, so it can happen!
Plus, technically it is grounded by the mount itself.
89 YJ 2.5L
09 KK Sport 4X4
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline
post #34 of 104 Old 12-19-2012, 05:09 PM
rescue575
2011 KK Liberty
Ok. I know the mount acts as the ground but wasn't sure if that would be compromised bolting it up to the painted surface of the truck. I'm glad I don't have to worry about that. I am kicking myself in the @ss right now though because I went with the firestik O-ring kit. Think that is going to become problematic. Worse case scenario I just change out the hardware I guess! Thanks for the feedback. Plus I think I should have ordered the 3 or 4 foot firefly. Think that may be a quick replacement. The 2 ft should be ok for now, but once I put the basket on the roof I think I'm go an have to go higher.
2011 Liberty Sport
post #35 of 104 Old 12-20-2012, 12:09 PM
Sagerist
Sagerist's Avatar
Well luckily antennas are the one mod that is cheap. Spend another 30 bucks and have your longer one. When i bought everything it was just the mount (comes with everything you need to connect), the spring, cabling, and the antenna. CB I already had. hardest part is getting all the plastic back in place once you pull it to route the cable, and i didnt pull it all the way out either, just enough to snake the cable through.
89 YJ 2.5L
09 KK Sport 4X4
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline
post #36 of 104 Old 12-20-2012, 12:45 PM
rescue575
2011 KK Liberty
Couldn't agree with you more. Not even that much. Can pick up a firefly for $20. Now question is (and accepting input) do I go 3' or 4'. I too have a plethora of radios but since even with today's technology they can't make a compact radio that's worth a dam so think I'm gonna just pick up a Cobra 75.
2011 Liberty Sport
post #37 of 104 Old 12-21-2012, 10:42 AM
Sagerist
Sagerist's Avatar
thats purely up to you. 3 feet will be plenty high to achieve good signal, but go big or go home! right? I would almost try and find something and measure it out just to be sure you are happy with how high it is. Cobra 75 is fine too, my brother and my buddy both have them and dont have any complaints about it. only funny thing is the scan function. once it hits a channel it will stay on that channel after receiving the signal and not go back into scan mode.
89 YJ 2.5L
09 KK Sport 4X4
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline
post #38 of 104 Old 12-21-2012, 01:16 PM
rescue575
2011 KK Liberty
Exactly. Once I get it all set up I can add another foot or two to the top of the two footer and see how rediculous it will look. I did get the HD spring so I do have room to go big if I decide to.
2011 Liberty Sport
post #39 of 104 Old 12-27-2012, 09:18 PM
musclezmarinara
2012 KK Liberty
Changed some things around in my jeep for the cb setup for better access
Also going to shorten up the antenna
Going to switch out my 4' to a 2'
2012 KK Cherokee * Arctic * Mineral Gray
- Mods - See Build Thread..
musclezmarinara is offline
post #40 of 104 Old 12-27-2012, 10:43 PM
Sagerist
Sagerist's Avatar
what?? Got tired of clipping power lines???
89 YJ 2.5L
09 KK Sport 4X4
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline
post #41 of 104 Old 01-03-2013, 07:58 AM
rescue575
2011 KK Liberty
Ok. For those who have mounted to the rear harch door jam and run coax through taillight, how did you pull off the molding in the rear to run it? Will it just pop out or is there a trick to it?
2011 Liberty Sport
post #42 of 104 Old 01-03-2013, 10:40 AM
DeltaForceB85
2011 KK Liberty
I got on this thread to ask the exact same question. LoL
-Josh
DeltaForceB85 is offline
post #43 of 104 Old 01-03-2013, 11:56 AM
rescue575
2011 KK Liberty
I got it out. It does pop out with a little prying from a screw driver, but I cannot figure out how to get the coax through the cent and into cabin. I have been using a coat hanger to guide but not finding it.
2011 Liberty Sport
post #44 of 104 Old 01-03-2013, 01:22 PM
rescue575
2011 KK Liberty
WOW! What a pain in the @ss that was. But finally got it in. If I have SWR issues, I'm blowing this truck up! Ha ha
2011 Liberty Sport
post #45 of 104 Old 01-03-2013, 08:39 PM
lfhoward
2008 KK Liberty
Nice job. I like how the color of your antenna matches your truck.
2008 Liberty Sport 4x4 Automatic
lfhoward is online now
Ultragauge....anyone install in their KK? bagwell KK Liberty Forum 6 10-03-2016 08:22 PM
3rd Row Custom Install jaaazzznutt KK Liberty Forum 8 04-30-2015 01:11 PM
Want to install amp and speaker scheki KK Liberty Forum 4 07-24-2011 05:15 PM
Want to install ParkSense arrowheadbob KK Liberty Forum 6 11-08-2010 09:25 AM
Cooling fan install SuperRliBerty KK Liberty Forum 2 10-30-2010 01:01 PM
