KK 3.7 same as WK/XK 3.7? - JeepForum.com
post #1 of 69 Old 07-22-2013, 08:55 AM Thread Starter
huntb
2008 KK Liberty
Just wondering if these engines are the same. I understand that there will be some differences but the more specific reason why I am asking is because of this thread that I saw over on the WK/XK boards...
http://www.jeepforum.com/forum/f67/v...-3-7l-1492188/
Would love to do this if possible
huntb is offline
post #2 of 69 Old 07-22-2013, 03:21 PM
Gageraid
2008 KK Liberty
Hmmmm This would be awesome.
Gageraid is offline
post #3 of 69 Old 07-22-2013, 03:27 PM
Sagerist
Sagerist's Avatar
Agreed. This sounds like an upgrade that would actually yield some real results if it works.
Colorado Jeep Club Member #286
89 YJ 2.5L
OME 36R's, Bilstein 5100's, Bserk 5/8" shackles, 33x10.5 BFG's on 15x8
09 KK Sport 4X4
235/75/16 GY Slnt Armor
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline
post #4 of 69 Old 07-23-2013, 06:30 AM Thread Starter
huntb
2008 KK Liberty
Bump.
TJ or Tom any input?
huntb is offline
post #5 of 69 Old 07-23-2013, 10:00 AM
heiliges
2012 KK Liberty
duuuude so gonna give it a try. guess i put the passport off for next paycheck. muwahaha, thanks for posting this.
heiliges is offline
post #6 of 69 Old 07-23-2013, 10:56 AM
heiliges
2012 KK Liberty
btw just read where its a throttle body for 2009 Durango or Dakota 4.7L engine. Just gotta find me one on the cheap for testing purposes. Someone posted they dyno tested it and got 10-15 hp below 3500 rpms. They also said at higher altitudes it would throw codes. Probably too lean at higher rpms unless you threw on bigger injectors. I live in florida to altitude is not a problem. question would be what happens when you lay on the gas real heavy. thinking possible stall but its worth a test to find out.
heiliges is offline
post #7 of 69 Old 07-23-2013, 12:24 PM Thread Starter
huntb
2008 KK Liberty
Yeah, if you could find one cheap enough it would totally be worth it.
Compatible vehicles
COMMANDER 07-10 3.7L
DAKOTA 07-11 Throttle Valve Assm; 3.7L
DODGE 1500 PICKUP 07-11 Throttle Valve Assm; 3.7L
DURANGO 07-09 Throttle Valve Assm; 3.7L
GRAND CHEROKEE 08-10 Throttle Valve Assm; 3.7L
LIBERTY 07-11 (3.7L)
MITSUBISHI RAIDER 07 Throttle Valve Assm; 3.7L
MITSUBISHI RAIDER 08 Throttle Valve Assm; (3.7L)
NITRO 07-11 3.7L
PACIFICA 07-08 3.8L
WRANGLER 07 Throttle Valve Assm; (3.8L)
This looks like it would work
huntb is offline
post #8 of 69 Old 07-23-2013, 12:31 PM
heiliges
2012 KK Liberty
Trick here is to find one with the wider intake. All the 3.7 will be the same size. Gotta find one of the 4.7.
heiliges is offline
post #9 of 69 Old 07-23-2013, 01:09 PM Thread Starter
huntb
2008 KK Liberty
No trick. Part number 53032837AB is the one that will fit the 4.7. You can find them new for around $150. Personally I'm just going to steal the one out of my roommates 4.7WK
Not really. He has an 06 which is still DBC. You need to get 08 and up. That is when Jeep made the change to DBW
huntb is offline
post #10 of 69 Old 07-23-2013, 07:21 PM
heiliges
2012 KK Liberty
since this is a test... i am looking to find one on the super cheap. still looking even tonight
heiliges is offline
post #11 of 69 Old 07-24-2013, 06:16 AM Thread Starter
huntb
2008 KK Liberty
I found a used one from an '11 RAM 1500 4.7 for $100 that I picked up on eBay. Will update when I get it in and install it. If it doesn't work I can always resell it and get my money back. It looks to be in excellent condition.
huntb is offline
post #12 of 69 Old 07-24-2013, 08:20 AM
Gageraid
2008 KK Liberty
Do you have a cold air intake? If this works, I am going to be so excited to see how it reacts to the Hypertech which I see you have, too.
Gageraid is offline
post #13 of 69 Old 07-24-2013, 08:35 AM Thread Starter
huntb
2008 KK Liberty
Yeah, I have the K&N CAI. Hopefully I won't need an adapter from the intake tube to the new TB. What I've heard reading thru the JK forums, it definitely helps out throttle response. I even saw dyno results that showed +21HP/+34TQ on the 3.8.
huntb is offline
post #14 of 69 Old 07-24-2013, 10:03 AM
myfirstjeep1
I am so interested in this. I have the hypertech and full exhaust and would love to see even more power
myfirstjeep1 is offline
post #15 of 69 Old 07-24-2013, 06:37 PM
Gageraid
2008 KK Liberty
yeah, i have the k&n cai. Hopefully i won't need an adapter from the intake tube to the new tb. What i've heard reading thru the jk forums, it definitely helps out throttle response. I even saw dyno results that showed +21hp/+34tq on the 3.8.
daaaaaaym.
Gageraid is offline
