K&N 63 Series vs 77 Series - JeepForum.com
post #1 of 6 Old 08-20-2013, 01:46 AM Thread Starter
Seagull96
2010 KK Liberty
I was just looking around and pretty much every website advertises that the K&N 63 series will only fit up to 2009. Is there any reason why it wouldn't fit on a 2010+?
If I was getting a CAI I'd imagine I'd rather have the plastic option compared to a metal one that would soak up heat..
http://www.summitracing.com/parts/kn.../model/liberty
http://www.jegs.com/i/K%26N/599/77-1...FZKi4AodK0sAow
Seagull96 is offline
post #2 of 6 Old 08-28-2013, 04:33 PM
jeepster1947
2012 KK Liberty
Also watching for an answer, Seagull....but I have another related question : why would 15 states declare the 77 series not street legal??
jeepster1947 is offline
post #3 of 6 Old 08-28-2013, 08:57 PM
tjkj2002
2002 KJ Liberty
Your stock airbox is a CAI,both of those you listed are not and will draw heated air from under the hood while the stock box draws cool air from the grill/hood area.
Also a good paper filter is much better then the K&N for a daily driver.If racing then yes you will benifit froma K&N but on a daily driver will only cause issues in 30-60k miles with all the extra dirt it's allowing into the engine.
tjkj2002 is offline
post #4 of 6 Old 08-28-2013, 09:30 PM
tommudd
2004 KJ Liberty
what he said
save the money you'd waste on a K&N and get some real toys
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #5 of 6 Old 08-28-2013, 09:42 PM
streetglideok
2005 KJ Liberty
If you want the effect of allowing dirtier air into the engine, and make the 2hp increase you get, save the money and take out your air filter completely. Not a lot different despite what K&N claims, which is put out by marketing teams. Take a google at splitfire spark plugs and the legal ills they faced. Don't believe the hype.
streetglideok is offline
post #6 of 6 Old 08-29-2013, 01:40 AM
Drednot
Absolutely as stated above. Oiled filters are a gimmick that allows a grimy build up inside the intake and on sensors. Take a good look at how the air flows through your factory air box and you will see its cold air intake.
What can help a bit, though, is to completely cover the air box and air tube with foil backed bubble wrap insulation to keep the intake temp as low as possible.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
