-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   K&N 63 Series vs 77 Series (http://www.jeepforum.com/forum/f292/k-n-63-series-vs-77-series-1564627/)
Seagull96 08-20-2013 01:46 AM
I was just looking around and pretty much every website advertises that the K&N 63 series will only fit up to 2009. Is there any reason why it wouldn't fit on a 2010+?
If I was getting a CAI I'd imagine I'd rather have the plastic option compared to a metal one that would soak up heat..
http://www.summitracing.com/parts/kn.../model/liberty
http://www.jegs.com/i/K%26N/599/77-1...FZKi4AodK0sAow
jeepster1947 08-28-2013 04:33 PM
Also watching for an answer, Seagull....but I have another related question : why would 15 states declare the 77 series not street legal??
tjkj2002 08-28-2013 08:57 PM
Your stock airbox is a CAI,both of those you listed are not and will draw heated air from under the hood while the stock box draws cool air from the grill/hood area.
Also a good paper filter is much better then the K&N for a daily driver.If racing then yes you will benifit froma K&N but on a daily driver will only cause issues in 30-60k miles with all the extra dirt it's allowing into the engine.
tommudd 08-28-2013 09:30 PM
what he said
save the money you'd waste on a K&N and get some real toys
streetglideok 08-28-2013 09:42 PM
If you want the effect of allowing dirtier air into the engine, and make the 2hp increase you get, save the money and take out your air filter completely. Not a lot different despite what K&N claims, which is put out by marketing teams. Take a google at splitfire spark plugs and the legal ills they faced. Don't believe the hype.
Drednot 08-29-2013 01:40 AM
Absolutely as stated above. Oiled filters are a gimmick that allows a grimy build up inside the intake and on sensors. Take a good look at how the air flows through your factory air box and you will see its cold air intake.
What can help a bit, though, is to completely cover the air box and air tube with foil backed bubble wrap insulation to keep the intake temp as low as possible.
The time now is 08:57 AM.
