JK Front Light Mounting Bar - Page 3 - JeepForum.com
post #31 of 74 Old 07-16-2012, 04:24 PM
rescue575
2011 KK Liberty
The cut:
The coat (first coat):
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #32 of 74 Old 07-17-2012, 12:02 PM Thread Starter
staubitzk
2011 KK Liberty
Looking good man. Can't wait to see it mounted. Also, are you going to use the relay? I wired mine up without it and was wondering how you were going to set yours up.
2011 Jeep Liberty Sport~OME Lift~ Tow Hooks ~ Skid Plates ~ Hitch ~ Built In Air Compressor ~ Black Rock 997s Steel Rims ~ Wrangler Duratracs ~ JK Front Mounted Lightbar ~ Tuff Stuff 22inch LED Bar ~
staubitzk is offline
post #33 of 74 Old 07-17-2012, 12:45 PM
rescue575
2011 KK Liberty
Yea I was going to just do it how the directions stated. What is the difference operationally if it is connected or not?
Not real familiar with playing with these wires!
2011 Liberty Sport
post #34 of 74 Old 07-17-2012, 04:23 PM
LII3ERTYSP0RT
2011 KK Liberty
Originally Posted by rescue575
Sounds good. Thanks. Looks like in a few weeks we will light up long island
Long Island here too. Where from
Dave
LII3ERTYSP0RT is offline
post #35 of 74 Old 07-17-2012, 08:11 PM
rescue575
2011 KK Liberty
Hey staub, do you recall what size lag screw you bought?
2011 Liberty Sport
post #36 of 74 Old 07-18-2012, 03:08 AM
Bmxer524
2011 KK Liberty
I'm from Lindenhurst, my friend with a 4" lift is from Lindenhurst as well, idk if he has an account on here. We have a friend from Bethpage with a 4" lift as well. And if rescue's info is right, then he is from Glen Oaks lol.
Bmxer524 is offline
post #37 of 74 Old 07-18-2012, 06:33 AM Thread Starter
staubitzk
2011 KK Liberty
Originally Posted by staubitzk View Post
I didn't use any silicone around the bolts as i drilled the pilot hole much smaller then the actual bolts so they held pretty good. Also, there is no need to worry about any water penetration. I tried using washers on top of the bolt by the head but they were not needed as well. It looked cleaner without them. As for the bolts, I went to Home Depot and picked up 4 small lag bolts. They worked like a charm.
Oh man I do not know the exact size sorry man but this is a picture of the exact bolt I used. Picked it up at Home Depot.
post #38 of 74 Old 07-18-2012, 06:43 AM
rescue575
2011 KK Liberty
Yea I went to home depot last night and matched up the head of the bolt so I believe it was a 3/8 bolt of that makes sense but the shortest they had was 2". It was like twice the length of the stock bolt. We're the bolt you bought longer?
2011 Liberty Sport
post #39 of 74 Old 07-18-2012, 06:52 AM Thread Starter
staubitzk
2011 KK Liberty
As we are on the subject of JK Bars and Offroad Lighting, I figured I would post some pictures of how to upgrade the Hella 500s from 55W to 100W. It is extremley easy to do. Thanks to VegasDragger45 for the insight
First, the 100W bulbs can be purchased from many auto parts stores. The bulb you are looking for is H3 100W.
http://contentinfo.autozone.com/znet...-100W/image/2/
The first thing you need to do is unscrew the plastic black tab at the base of the light.
The tab folds down and you just need to pull apart the actual light from the housing. It came apart extremely easy.
Once the light is out, you will see the two connections for the light. They are super simple and very self explanatory. Pry the connections off and release the light from the bracket. You just need to apply downward pressure the one side of the bracket and it should hinge open so you can remove the bulb.
Replace the old bulb with your new one, making sure not to touch the glass on the bulb, and repeat the steps in reverse. Close the hinge that secures the light, attach the wiring, put the light back in the housing, and screw in the plastic tab. It took me about 7 minutes to do both lights.
They make a huge difference compared to the 55W. Will post pics of the lights on soon.
post #40 of 74 Old 07-18-2012, 07:03 AM Thread Starter
staubitzk
2011 KK Liberty
I am pretty sure it was the 2 inch bolt. It is only going through the plastic bumper so the length i'm sure won't be too much of any issue. If anything you may hit the steel frame and make it super secure
post #41 of 74 Old 07-18-2012, 07:20 AM
rescue575
2011 KK Liberty
Very good. Thanks for the info! Can't wait to get this damn thin on. Was delayed yesterday and couldn't get the second coat of paint on it.
2011 Liberty Sport
post #42 of 74 Old 07-22-2012, 03:36 PM
rescue575
2011 KK Liberty
Hey.....when you ran your switch, what did you ground the switch to? Something under the console or under the dash?
2011 Liberty Sport
post #43 of 74 Old 07-22-2012, 04:38 PM
VegasDragger45
2010 KK Liberty
I grounded mine to the ground on the cigarette lighter and it works with no issue.
2010 KK, 2" Daystar lift, 245/75/16 BFG All-Terrains, interior LED's, front rear and cargo liner weather tech's, Pioneer AVH-p4400BT, GEX-P920XM, Kicker 6" in front 5 1/4" in rear, PB 2.75" in dash, Kicker 300.1 amp, Pioneer TS-SWX310, JK light bar with Hella 500 ff and 100w bulb, BOYO rear view camera, JBA exhaust, K&N drop in filter and more to come.
VegasDragger45 is offline
post #44 of 74 Old 07-23-2012, 02:02 AM
Bmxer524
2011 KK Liberty
I think it was something under the console. I don't remember where exactly.
Bmxer524 is offline
post #45 of 74 Old 07-23-2012, 03:44 AM
jsburton84
2008 KK Liberty
I grounded my switch to a bolt behind the dash bezel.
pics here:
http://www.jeepforum.com/forum/f292/...l#post13265035
2008 KK sport 4x4
1998 XJ sport 4x4 (sold)
jsburton84 is offline
traction control/ 4wd light and 4wd service light r1967a KK Liberty Forum 28 12-29-2013 09:56 PM
Planning on buying these Off-Road Lights, Opinions? Mounting? JSAN KK Liberty Forum 0 06-13-2012 03:46 AM
gas cap light sofixj KK Liberty Forum 2 02-13-2012 09:32 AM
Air Bag light ChuckPink KK Liberty Forum 4 12-03-2010 03:54 PM
Fog Light Aim ackeiyword KK Liberty Forum 2 10-30-2010 09:05 AM
