JK Front Light Mounting Bar - Page 2 - JeepForum.com
post #16 of 74 Old 07-11-2012, 07:56 AM
rescue575
2011 KK Liberty
So far looks good.......my first 3 of I'm sure many questions I'm gonna have while I'm installing mine:
1. I assume from your pictures at you meant to remove the grill (not bumper) right?
2. Did you use the bolts in all 4 holes?
3. Did you mount lights at all first to make sure you will have enough room for them in front of the grill?
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #17 of 74 Old 07-11-2012, 09:01 AM Thread Starter
staubitzk
2011 KK Liberty
Good catch...sorry didn't have my coffee this morning. Yes I did remove the Grill but not the bumper. I did use the bolts in all four holes I aligned the front of the bar with the edge of the bumper before it slanted downward. You will see once you take the grill off. The back end of the bar was right to the edge of the bumper. As for the lights, I made sure to leave at least a 1 and a half gap between the mounting plate on the bar and the grill. The grill does have some play if I need a little more room. Since I am getting the Hella 500s, from this angle, you can see that it does not extend back past the mounting point so it should fit no problem.
2011 Jeep Liberty Sport~OME Lift~ Tow Hooks ~ Skid Plates ~ Hitch ~ Built In Air Compressor ~ Black Rock 997s Steel Rims ~ Wrangler Duratracs ~ JK Front Mounted Lightbar ~ Tuff Stuff 22inch LED Bar ~
staubitzk is offline
post #18 of 74 Old 07-11-2012, 12:07 PM
rescue575
2011 KK Liberty
Ahh. Yea you should have no problem with those. I got the KC slimlites so hopefully I will have same! Your install looks good so far though, thanks for the step by step. Will deff make my life a bit easier. I am waiting for the lights so j can measure it up, make the cuts then I'm gonna paint the bar white to match the truck before the install.
Did you use any kind of silicone on the bumper around the holes? Did you mount any washers and nuts under the bumper or just crewed right in? Also did you use the supplied bolts?
P.S. I told you I would have a hundred questions. Lol.
2011 Liberty Sport
post #19 of 74 Old 07-11-2012, 01:02 PM Thread Starter
staubitzk
2011 KK Liberty
I didn't use any silicone around the bolts as i drilled the pilot hole much smaller then the actual bolts so they held pretty good. Also, there is no need to worry about any water penetration. I tried using washers on top of the bolt by the head but they were not needed as well. It looked cleaner without them. As for the bolts, I went to Home Depot and picked up 4 small lag bolts. They worked like a charm.
post #20 of 74 Old 07-11-2012, 02:57 PM
VegasDragger45
2010 KK Liberty
Just want to add that the hellas fit with no issues between the grill. I had to add washers under the lights before i bolted them in or I was unable to angel them.
2010 KK, 2" Daystar lift, 245/75/16 BFG All-Terrains, interior LED's, front rear and cargo liner weather tech's, Pioneer AVH-p4400BT, GEX-P920XM, Kicker 6" in front 5 1/4" in rear, PB 2.75" in dash, Kicker 300.1 amp, Pioneer TS-SWX310, JK light bar with Hella 500 ff and 100w bulb, BOYO rear view camera, JBA exhaust, K&N drop in filter and more to come.
VegasDragger45 is offline
post #21 of 74 Old 07-11-2012, 03:01 PM
VegasDragger45
2010 KK Liberty
Pics of washers
post #22 of 74 Old 07-12-2012, 06:44 AM Thread Starter
staubitzk
2011 KK Liberty
Originally Posted by VegasDragger45 View Post
Pics of washers
Thanks VegasDragger I will be making a trip to Home Depot to pick up a couple bags of washers.
post #23 of 74 Old 07-12-2012, 06:49 AM
rescue575
2011 KK Liberty
Wow! Your not kidding about having to add washers. I assume you has to replace the bolts for longer ones right?
2011 Liberty Sport
post #24 of 74 Old 07-12-2012, 07:24 AM
VegasDragger45
2010 KK Liberty
Actually no the bolts were long enough that they still stick out on the bottom through the nut. I've had them on since December and it's never worked its way loose.
post #25 of 74 Old 07-12-2012, 07:32 AM
rescue575
2011 KK Liberty
Good to know....I bought the KC's but I'm sure I will have the same issue
2011 Liberty Sport
post #26 of 74 Old 07-16-2012, 07:03 AM Thread Starter
staubitzk
2011 KK Liberty
Updated:
Just installed my Hella 500s with rock guard and smoked lenses. I also installed a custom Zombie rocker switch in the center console.
post #27 of 74 Old 07-16-2012, 08:20 AM
rescue575
2011 KK Liberty
Originally Posted by staubitzk
Updated:
Looks real good man. Finally got my lights over the weekend. They look real sharp in chrome! Now I need to fabricate the bar. Let me ask you this.....think you posted that you cut about 2" of the bar.....did that leave you with a lot of extra room cause when I measured I feel that I didn't need to Gotham far? I wanted to try and keep the bar cut close to the grill.
2011 Liberty Sport
post #28 of 74 Old 07-16-2012, 08:33 AM Thread Starter
staubitzk
2011 KK Liberty
Ya I though the same thing. I went back and rechecked everything and I went and just did a 1 inch cut and took small cuts after that to get it perfect. I believe it worked out to be about an inch and a quarter give or take. My only suggestion would be to drill the bar to the bumper first, then cut and check the fit with the grill.
post #29 of 74 Old 07-16-2012, 09:57 AM
rescue575
2011 KK Liberty
Ok...I just cut it about 1 1/2" to be safe. Should be fine with that!
2011 Liberty Sport
post #30 of 74 Old 07-16-2012, 10:22 AM Thread Starter
staubitzk
2011 KK Liberty
Post pictures when your done. I want to see it in white!
traction control/ 4wd light and 4wd service light r1967a KK Liberty Forum 28 12-29-2013 09:56 PM
Planning on buying these Off-Road Lights, Opinions? Mounting? JSAN KK Liberty Forum 0 06-13-2012 03:46 AM
gas cap light sofixj KK Liberty Forum 2 02-13-2012 09:32 AM
Air Bag light ChuckPink KK Liberty Forum 4 12-03-2010 03:54 PM
Fog Light Aim ackeiyword KK Liberty Forum 2 10-30-2010 09:05 AM
