JK Bumper Lightbar Install Walkthrough - JeepForum.com
post #1 of 12 Old 07-11-2012, 08:36 AM Thread Starter
staubitzk
2011 KK Liberty
Finally got a chance to install the JK lightbar on my Liberty. I have not found a detailed walk through yet so here we go...
The first thing you need to do is remove the front bumper.
After the front bumper is removed, line up the JK bar with the bumper and tape it into place.
Insert the grill over the JK bar and measure how far you need to cut the bracket. I needed to cut about 2 inches off the bracket. I would start small and work your way up so that you do not cut too much off.
To cut the bracket, I used an air grinder which did the job nicely. It took about 20 minutes all together to cut both sides. Another thing I learned is to cut and measure each side individually.
Once the bar is cut and fits nicely, I used rattle can matte black to cover the cuts and to spray the bolts black.
Once the parts dried, I realigned the bar to the bumper and marked the hole closest to you with a pencil. I then took a small drill bit and drilled a small pilot hole for the bolts. This is the worst part but after researching and finding a product called Bumper Plugs to fill the hole, it wasn't so bad.
Once the pilot holes were drilled I simply screwed in my bolts in the first two holes, then repeated the process for the back. The bar felt extremely durable and sturdy however you obviously do not want to use it as a towing point
Here is the finished result. It took about an hour to complete and was very easy to do. I will be adding the Hella 500s soon!
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
2011 Jeep Liberty Sport~OME Lift~ Tow Hooks ~ Skid Plates ~ Hitch ~ Built In Air Compressor ~ Black Rock 997s Steel Rims ~ Wrangler Duratracs ~ JK Front Mounted Lightbar ~ Tuff Stuff 22inch LED Bar ~
staubitzk is offline
post #2 of 12 Old 07-11-2012, 01:03 PM
Bmxer524
2011 KK Liberty
Nice write up! I would suggest adding the how-to on lost's KK tech section. Could never hurt to have it for the new guys wanting it over there. And there's a beach meet that's getting planned for sore thumb I think if you ever wanted to go and meet up with us.
Bmxer524 is offline
post #3 of 12 Old 07-11-2012, 02:04 PM Thread Starter
staubitzk
2011 KK Liberty
Sounds good I will throw it over there as well. Ya man I am always down for any beach trips. Will be there this Friday
post #4 of 12 Old 07-11-2012, 02:48 PM
Bmxer524
2011 KK Liberty
Check out the NE section on Lost, we do quite a few meet and greets/mod days with everyone.
Bmxer524 is offline
post #5 of 12 Old 07-11-2012, 03:05 PM Thread Starter
staubitzk
2011 KK Liberty
Can u send me the link?
post #6 of 12 Old 07-11-2012, 06:15 PM
Bmxer524
2011 KK Liberty
Bmxer524 is offline
post #7 of 12 Old 08-31-2012, 02:45 AM
matteagle
2012 KK Liberty
@Staubitzk would it be possible for you to relink those photos. I may try to do this instead of the bull bar mount. I think this looks wayyyy slicker but I'm nervous about drilling into the bumper of my new toy!
matteagle is offline
post #8 of 12 Old 08-31-2012, 11:20 AM
eoerikson3
2011 KK Liberty
They say it is not really yours until you drill your first hole.
-Oscar
Chrome may not get you home, but sometimes it looks nice.
2011 Liberty Sport
Added tow hitch, tow hooks, skid plates, foglight kit and headlight masks, remote start, chrome steps, and Cooper Discoverer A/T3 235/75R16.
eoerikson3 is offline
post #9 of 12 Old 02-14-2014, 06:57 PM
s2killa
2011 KK Liberty
needed this lool
Instagram-DHR_S2KILLAA
11 Liberty KK l Daystar 2" l Rock Crawler 15x8 3.75" l M/T Baja MTZ 31x10.50
s2killa is offline
post #10 of 12 Old 02-14-2014, 10:05 PM
jmic0925
2012 KK Liberty
Are the photos not working?
jmic0925 is offline
post #11 of 12 Old 02-15-2014, 10:27 AM
s2killa
2011 KK Liberty
yea i didnt get the photos either. but i got an idea but photos will be awesome haha
s2killa is offline
post #12 of 12 Old 02-16-2014, 09:26 AM
carlosburitica
2010 KK Liberty
here is my post with pics
http://www.lostjeeps.com/forum/phpBB...?f=104&t=74082
I WILL UPDATE ALL THE INSTALL INFO
HERE ARE SOME PICTURES.
i think that hardest part is to remove the bumper and to put in your mind that you are going to cut two 2" long lines on you bumper thinking that if you miscalculate you are going to damage your bumper.....
1. remove the front bumper. here is a good info if how to: http://www.jeepforum.com/forum/f28/k...emoval-741659/
install the kc light bar.
materials:
4 2" 5/6 bolts
12 5/16 nuts
4 5/6 washers
5/16 drill bit.
4 1" steel spacers i found 3/8" they fit loose but do the job
1. you need to drill an extra hole on the light bar to fit the bumper support
2. drill two holes in the bumper support. they align almost with the vertical line in front of the BS in both sides, maybe couple of millimeter to the center of the vehicle.
3. insert the 2" 5/16" bolts, install washers and nuts
4. you can easily use a socket wrench or wrench to tight the nuts, i suggest to do this once you have the light bar instaled, because this part of the support is little tilted in and making it the bolts tight will make it very hard to install the bar.
5. install the spacers
6. install the kc bar. you may want to tight the nuts at this point to make the markings on the bumper
at first i fitted the bar directly over the spacer, but them i found that i could use another nut elevate the bar 1/4" more.
7. try to install the bumper with out the bar, so you can use the bolts as a reference point to mark the lines to cut the bumper, i used a red pen to do it. use a jig saw and then a tungsten bit on a dremel for this task, ( ill update once i download the other pics)
will update the lenght later. i cut by small increments until it fitted tight
make sure to remove some of the material inside the bumper cover to fit the bar
install the bumper and grill and you are done
had a lot of fun and lot more to come....
carlosburitica is offline
KK CB Install: Write up GoodPrepper KK Liberty Forum 103 06-10-2016 07:55 PM
3rd Row Custom Install jaaazzznutt KK Liberty Forum 8 04-30-2015 01:11 PM
how to install back up cam?? sofixj KK Liberty Forum 9 01-04-2014 07:56 PM
Want to install ParkSense arrowheadbob KK Liberty Forum 6 11-08-2010 09:25 AM
Cooling fan install SuperRliBerty KK Liberty Forum 2 10-30-2010 01:01 PM
