-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   JK Bumper Lightbar Install Walkthrough (http://www.jeepforum.com/forum/f292/jk-bumper-lightbar-install-walkthrough-1391710/)
staubitzk 07-11-2012 07:36 AM
Finally got a chance to install the JK lightbar on my Liberty. I have not found a detailed walk through yet so here we go...
The first thing you need to do is remove the front bumper.
http://www.djdailyinsider.com/jeepimages/1.JPG
http://www.djdailyinsider.com/jeepimages/2.JPG
After the front bumper is removed, line up the JK bar with the bumper and tape it into place.
http://www.djdailyinsider.com/jeepimages/3.JPG
Insert the grill over the JK bar and measure how far you need to cut the bracket. I needed to cut about 2 inches off the bracket. I would start small and work your way up so that you do not cut too much off.
http://www.djdailyinsider.com/jeepimages/4.JPG
To cut the bracket, I used an air grinder which did the job nicely. It took about 20 minutes all together to cut both sides. Another thing I learned is to cut and measure each side individually.
http://www.djdailyinsider.com/jeepimages/5.JPG
http://www.djdailyinsider.com/jeepimages/6.JPG
Once the bar is cut and fits nicely, I used rattle can matte black to cover the cuts and to spray the bolts black.
http://www.djdailyinsider.com/jeepimages/7.JPG
Once the parts dried, I realigned the bar to the bumper and marked the hole closest to you with a pencil. I then took a small drill bit and drilled a small pilot hole for the bolts. This is the worst part but after researching and finding a product called Bumper Plugs to fill the hole, it wasn't so bad.
http://www.djdailyinsider.com/jeepimages/8.JPG
Once the pilot holes were drilled I simply screwed in my bolts in the first two holes, then repeated the process for the back. The bar felt extremely durable and sturdy however you obviously do not want to use it as a towing point :nono:
http://www.djdailyinsider.com/jeepimages/9.JPG
Here is the finished result. It took about an hour to complete and was very easy to do. I will be adding the Hella 500s soon!
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
http://www.djdailyinsider.com/jeepimages/11.JPG
Bmxer524 07-11-2012 12:03 PM
Nice write up! I would suggest adding the how-to on lost's KK tech section. Could never hurt to have it for the new guys wanting it over there. And there's a beach meet that's getting planned for sore thumb I think if you ever wanted to go and meet up with us.
staubitzk 07-11-2012 01:04 PM
Sounds good I will throw it over there as well. Ya man I am always down for any beach trips. Will be there this Friday :cheers2:
Bmxer524 07-11-2012 01:48 PM
Check out the NE section on Lost, we do quite a few meet and greets/mod days with everyone.
staubitzk 07-11-2012 02:05 PM
Can u send me the link?
Bmxer524 07-11-2012 05:15 PM
http://www.lostjeeps.com/forum/phpBB...forum.php?f=23
That's the NE section.
matteagle 08-31-2012 01:45 AM
@Staubitzk would it be possible for you to relink those photos. I may try to do this instead of the bull bar mount. I think this looks wayyyy slicker but I'm nervous about drilling into the bumper of my new toy!
eoerikson3 08-31-2012 10:20 AM
They say it is not really yours until you drill your first hole.
s2killa 02-14-2014 05:57 PM
needed this lool
jmic0925 02-14-2014 09:05 PM
Are the photos not working?
s2killa 02-15-2014 09:27 AM
yea i didnt get the photos either. but i got an idea but photos will be awesome haha
carlosburitica 02-16-2014 08:26 AM
here is my post with pics
http://www.lostjeeps.com/forum/phpBB...?f=104&t=74082
I WILL UPDATE ALL THE INSTALL INFO
HERE ARE SOME PICTURES.
i think that hardest part is to remove the bumper and to put in your mind that you are going to cut two 2" long lines on you bumper thinking that if you miscalculate you are going to damage your bumper.....
1. remove the front bumper. here is a good info if how to: http://www.jeepforum.com/forum/f28/k...emoval-741659/
install the kc light bar.
materials:
4 2" 5/6 bolts
12 5/16 nuts
4 5/6 washers
5/16 drill bit.
4 1" steel spacers i found 3/8" they fit loose but do the job
1. you need to drill an extra hole on the light bar to fit the bumper support
http://i893.photobucket.com/albums/a...psd4d0dab4.jpg
2. drill two holes in the bumper support. they align almost with the vertical line in front of the BS in both sides, maybe couple of millimeter to the center of the vehicle.
http://i893.photobucket.com/albums/a...psfa882b2b.jpg
3. insert the 2" 5/16" bolts, install washers and nuts
http://i893.photobucket.com/albums/a...ps66a87a81.jpg
4. you can easily use a socket wrench or wrench to tight the nuts, i suggest to do this once you have the light bar instaled, because this part of the support is little tilted in and making it the bolts tight will make it very hard to install the bar.
http://i893.photobucket.com/albums/a...ps3d0d6ce8.jpg
5. install the spacers
http://i893.photobucket.com/albums/a...ps81c73328.jpg
http://i893.photobucket.com/albums/a...ps6a432899.jpg
6. install the kc bar. you may want to tight the nuts at this point to make the markings on the bumper
http://i893.photobucket.com/albums/a...ps3d203e4c.jpg
at first i fitted the bar directly over the spacer, but them i found that i could use another nut elevate the bar 1/4" more.
http://i893.photobucket.com/albums/a...ps39958abc.jpg
7. try to install the bumper with out the bar, so you can use the bolts as a reference point to mark the lines to cut the bumper, i used a red pen to do it. use a jig saw and then a tungsten bit on a dremel for this task, ( ill update once i download the other pics)
http://i893.photobucket.com/albums/a...psc0d11265.jpg
will update the lenght later. i cut by small increments until it fitted tight
http://i893.photobucket.com/albums/a...pscc9c156d.jpg
make sure to remove some of the material inside the bumper cover to fit the bar
http://i893.photobucket.com/albums/a...ps8f52f823.jpg
http://i893.photobucket.com/albums/a...ps31259377.jpg
install the bumper and grill and you are done
http://i893.photobucket.com/albums/a...ps40c7b1b0.jpg
http://i893.photobucket.com/albums/a...psa3e6ed0f.jpg
had a lot of fun and lot more to come....
The time now is 03:24 PM.
