-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   Jet Lift Kit (http://www.jeepforum.com/forum/f292/jet-lift-kit-1546138/)
2012JETLIMITED 07-07-2013 04:28 PM
Jet Lift Kit
Im looking for any information about lifting my 2012 Liberty Jet Limited. Im looking into a sky jacker 2.5in coil over lift. Whats the biggest tire you can run with the 20in wheels after install? Are the any pros/cons with the sky jacket system?
tommudd 07-08-2013 04:07 AM
Skyjacker= NO
Same rating on the springs as stock and will sag quickly
Go OME or the adjustable coilovers from JBA
Do it right the first time and you'll be happy
khalilw 07-08-2013 11:30 AM
hahaha I knew tomm would come to the rescue :rofl::rofl::rofl::rofl::rofl::rofl:
2012JETLIMITED 07-08-2013 11:57 AM
That's why I asked before I purchased, Thanks tommud.
LibertyRS 07-08-2013 12:49 PM
I'm running 275/45/20 (29.74) no rub at stock height. I'm sure with a lift you can get at least 275/50/20 (30.84) maybe even bigger.
Bmxer524 07-08-2013 02:04 PM
Tom confirmed what I thought lol. I was going to post last night that I think skyjacker had the same spring rate as stock, but wasn't sure so I just waited for Tom to say it lol
huntb 07-08-2013 02:55 PM
I don't think I would dare go that wide at almost 31"
2012JETLIMITED 07-08-2013 08:31 PM
Would you think the 275/45/r20s would fit good after a 2.5in lift? Or would that be cutting it close?
Thanks for the input guys.
huntb 07-09-2013 08:27 AM
I guess if LibertyRS has those with stock height and no rub then they should work. I just have never seen anyone go wider than 265 and I thought that might even be pushing it depending on the backspacing of the rim
2012JETLIMITED 07-09-2013 09:59 AM
Yeah, going by how my stock 245/50r20 fit. I doubt I'll be able to squeeze 275's at stock height. Who knows ill find out sooner or later.
LibertyRS 07-09-2013 04:51 PM
275s fit no problem with a 45 side wall. 275/50/20 will require some modification
2012JETLIMITED 07-09-2013 05:47 PM
Thanks, one more dumb question. My wheels are 20x7.5 (my mistake thought they were 8.5)I believe 7.5 might not be wide enough to mount a 275/45r20? Any input on that?
tommudd 07-09-2013 09:34 PM
Best thing to do is ditch the 20s and forget about the rubber bands and get some real tires and wheels
Drop to 16s / good set of 245-75-16s and you won't be laughed at
Nothing much worse than a JEEP with 20s and tires that jar your teeth going over a wad of gum
JoeyC99 07-09-2013 11:30 PM
Agreed with tommudd. Especially if you are thinking about changing rims anyway, best thing to do is go for a smaller rim and a bigger sidewall.
Skipper6413 07-10-2013 08:31 PM
Agree with Tom. I have a 11 Jet 4x4 and I swapped my wheels with my wife's KJ which was a 4x2. I like the 16s with some very aggressive tires much much better. Not to mention my wife's KJ is much nicer with my jet wheels. I'm in a much better position for trails now!
The time now is 12:58 AM.
