jeep liberty off road tires - JeepForum.com
post #1 of 8 Old 01-12-2014, 07:33 PM Thread Starter
chrisdipo
i want to run 31 inch tires on my jeep but i dont now the tire specs (ex: 245/75/16=30 inch) does anybody know the size for a 31 inch tire ?
chrisdipo is offline
post #2 of 8 Old 01-12-2014, 07:37 PM
khalilw
2011 KK Liberty
khalilw is offline
post #3 of 8 Old 01-12-2014, 08:04 PM
tommudd
2004 KJ Liberty
Just know that getting over a 30 inch you will be loosing power and gas mileage
lifted with 245-75-16s works great , taller then above happens
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
post #4 of 8 Old 01-12-2014, 09:26 PM
streetglideok
2005 KJ Liberty
Keep in mind, 31" tires is a bit subjective. Actual 31x10.5 tires aren't 31" tall. They are pretty close in diameter to 245/75R16, but wider. Their diameter is influenced by tread type, and wheel width as well. 265/75R15(note 15" wheel in the size) is about identical to a 31x10.5r15. My 30x9.5 tires are pretty meaty, and are barely smaller in diameter to a mild 31" tire. I've just thrown a bunch of numbers up and added to confusion,lol. Are you wanting to run "31 inch tires" just because that's what you hear people run, or are you lifted and you have a set need? If you are lifted, then 245/75R16 is all you'll need, and will for all intents and purposes be the same diameter as a 31x10.5 tire, just not the width. If you want to run a tire that says 31x10.5r15 on it, then you need 4" offset 15" wheels, of only a couple of brands that will fit, plenty of lift, flattened pinch welds, etc.
streetglideok is offline
post #5 of 8 Old 01-12-2014, 09:45 PM
Bmxer524
2011 KK Liberty
245/75-16s are pretty close to a 31x10 tire. Most go with that size anyways. Could always go standard and find a "legit" 31" tall tire, but I'm not too sure if they make 31x(10/10.5)x16 and if they do it won't be common. A common size would be 31x10.5x15, but as said it will need the right 15" rims(only some steel rims with the right backspacing, I believe it's about 4"), and about 2.5-3" of lift.
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
post #6 of 8 Old 01-13-2014, 12:31 AM
streetglideok
2005 KJ Liberty
I'm running Ironman springs front and rear, about 22" from fender to hub. I had 15" alloy wheels, 235/75r15 tires on it when I bought it. I now have 30x9.5r15 Cooper STTs on it now. Its about as wide as 245mm tires, just a hair smaller diameter. Due to the 4" offset, I do get rubbing of the fenders at the pinchweld. I had slight rubbing at stock sagged height with the smaller tires at the pinchwelds. 10.5" wide tires are about 265mm wide, to help with comparisons.
post #7 of 8 Old 01-13-2014, 03:56 AM
JoeTDI
2012 KK Liberty
Tire Rack has a specs sheet for every tire they have in every size.... it lets you compare on a chart side by side all the different tire sizes, weights, tread width, section width, diameter, revolutions per mile, max psi, max load, etc etc...just click on whatever tire you are interested in and scroll down to see the specs sheet.
Current: 2012 KK-2012 MK Patriot
Past: 1965 CJ5-1985 XJ-1995 ZJ-1999 TJ-2002 KJ-2006 KJ
JoeTDI is offline
post #8 of 8 Old 01-13-2014, 04:35 PM Thread Starter
chrisdipo
thank you everybody for all of your help !!! I got my answer I forgot to mention i have a 2inch lift and i will go with the highly recommended 245/75R16 thank you everybody so much !
