Jeep kk diesel crd. 2.8 diesel 2010 Maf problems Mass Air flow problems 48000 kms - JeepForum.com
post #1 of 27 Old 12-24-2013, 09:01 AM Thread Starter
fabioschallbr
My jeep' s check engine light was on so I went to the dealer and according to the computer screening it was a problem with the mass air flow. I replaced it for a new one. The smoke diminished and the engine is working well but it seems to me that the car still not a 100 percent and the check engine light is still on. Did anyone have this problem? If so, is this problem related to something else?
Thank you!
fabioschallbr is offline
post #2 of 27 Old 12-25-2013, 08:59 AM
koutoukos
Originally Posted by fabioschallbr
My jeep' s check engine light was on so I went to the dealer and according to the computer screening it was a problem with the mass air flow. I replaced it for a new one. The smoke diminished and the engine is working well but it seems to me that the car still not a 100 percent and the check engine light is still on. Did anyone have this problem? If so, is this problem related to something else? Thank you!
Try to find a hole at the turbo hoses. It's the most common problem for the crd's at approximately 50k km.
koutoukos is offline
post #3 of 27 Old 12-25-2013, 11:03 AM
MtBJet
At 48k kms your MAF should have been fine... With proper maintenance it should last a very long time. If your CEL is still on, it probably wasn't the issue. Did you delete the code or reset the ECU after install of the new MAF?
MtBJet is offline
post #4 of 27 Old 12-25-2013, 11:06 AM
MtBJet
Check all of your vacuum lines, not just at the turbo.
MtBJet is offline
post #5 of 27 Old 12-25-2013, 11:19 AM
MtBJet
I should add: a good (proper) way to do this is to pressurize the system, stick your head in the engine bay and listen for hissing. If you can't find it by ear and feel, use a spray bottle filled with a light soap and water solution. Spray the area and you'll see bubbles.
An easy DIY to pressurize the system is to go to your local automotive store, buy a short section of hose that covers the turbo input (where air enters from the MAF) and a rubber valve stem. Then, go to your local hardware store and purchase a PVC cap that fits inside the hose. Oh, at either sore, purchase hose clamps to clamp the hose over the turbo end and the PVC cap. Drill a hole in the PVC cap that will accept the valve stem... It should pop in... If not, use silicone to seal it in. Once all of this is done, clamp the cap into the hose and the other end of the hose to the turbo. Using a regulated air source (you don't want to drive 100 PSI into the system) pressurize the system. A simple bike pump will even work. Then, listen for the hiss(es).
MtBJet is offline
post #6 of 27 Old 01-10-2014, 04:33 PM Thread Starter
fabioschallbr
Good night
I sent my jeep to the dealer to have it checked. They checked all hoses intake and turbo, nothing was wrong. they clear the code error ecu from mass air flow but a day later the check engine was back on. They checked the Eletric wire for mass air flow and does not show any problem. So far Nothing is resolved.
They told me that maybe the ECU is presenting problems.
When they said the ECU could have problems I remembered I installed chip mods in the original wire to make itmore powerful. I used it for four months and after this period I took it away because It was not making any difference, in addition the car began to make more smoke. The check engine only got on three months after I removed the chips mods.
The car continues at the dealer for more tests.
If anyone can give me any direction I would very much appreciate.
Thanks,
By the way, sorry for not replying earlier. I was traveling.
post #7 of 27 Old 01-10-2014, 10:16 PM
MtBJet
What chip was used? Was it installed/removed properly? Being that the ECU is throwing a MAF code (do you have the specific code?) that narrows the problem down pretty tight. It can be a vacuum/boost leak (+/- unmetered air), a bad MAF sensor or something with the ECU. Considering they have checked all of the hoses/turbo and the MAF sensor (I'm assuming that's what you meant by "electric wire") that almost completely narrows it down to the ECU. If you're still getting darker exhaust (smoke) this could explain it. The ECU could be misreading the voltage from the MAF, think the engine is running lean and be throwing more fuel than needed at it. Just a thought.
MtBJet is offline
post #8 of 27 Old 01-12-2014, 07:58 AM Thread Starter
fabioschallbr
Hello,
Thanks again.
I checked the chip I used and confirmed it modifies the signal from the ECU.
The link is below (don't mean do give any trouble, just in case you want to check).
http://www.ebay.com/itm/Chip-Tuning-...item19db7388b5
About the chip installed, I just plugged in the common rail fuel pressor sensor. The other plug was connected as bypass in the original harness. To remove I just unplugged, nothing else.
At the dealer they told me they checked the signal in the harness sensor to ECU and it was ok. I believe they have not checked the vacumm boost leak yet.
About the smoke exhausts, when the car is in the idle march rpm it does not make smoke. The smoke only appears when the accelerator is used to put power in the car
About the code error, the dealer plugged the computer to my car and onlu one code error problem appeared. It was with MAF only nothing else.
Thanks any help
post #9 of 27 Old 01-12-2014, 08:26 AM
RENE65
2008 KK Liberty
Do you know the code ?? p0???
RENE65 is offline
post #10 of 27 Old 01-12-2014, 09:54 AM
koutoukos
post #11 of 27 Old 01-12-2014, 09:56 AM
koutoukos
Originally Posted by fabioschallbr View Post
Hello,
My strong advice to you is not to do anything else before they check it...
post #12 of 27 Old 01-13-2014, 06:26 AM Thread Starter
fabioschallbr
Hello everybody
The call me at dealer place this morning and told me they find a Hose with damage PN 55037958AB from admission . I ask if the dealer is sure this is the problem with check engine ligth . They not confirm only tell me they need replace first to check.
The picture of the house is attached.
This hose is from Charge air cooler Inlet can be??
Thanks
post #13 of 27 Old 01-13-2014, 02:19 PM
MtBJet
Hello everybody The call me at dealer place this morning and told me they find a Hose with damage PN 55037958AB from admission . I ask if the dealer is sure this is the problem with check engine ligth . They not confirm only tell me they need replace first to check. The picture of the house is attached. This hose is from Charge air cooler Inlet can be?? Thanks
That could totally be the problem. When the engine is running under vacuum it will be pulling unmetered air into the engine and when the engine is under boost it's pushing metered air out, so the engine is always looking for a certain metered volume but it's not there. This would also be the cause of the smoke. When you're on the accelerator, you're under boost. The MAF reads a certain amount of air, which it tells the ECU. The ECU then tells the fuel pumps to dump in the fuel needed for that amount of air. Since that amount of air isn't there (leaking out of the intercooler [charged air] hose) you're running rich... And that's what's causing the smoke.
MtBJet is offline
post #14 of 27 Old 01-13-2014, 02:20 PM
MtBJet
Oh, and yes, this would also cause a MAF related CEL.
MtBJet is offline
post #15 of 27 Old 01-14-2014, 05:46 AM Thread Starter
fabioschallbr
I will order the hose
But in the dealer here they not have because this car is only UK or AU market . iam in US . Any one know where I can order fast this hose 55037958AB ??
Thanks a lot for your help MTBJET
