JBA 2.5"rear coils - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > JBA 2.5"rear coils
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Boss is away but Erin is here to STAY with a F.Y.S. SaFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-24-2015, 02:54 PM   #1
mtbiker
2011 KK Liberty
JBA 2.5"rear coils
Anyone have these? My OME HD springs have settled to about an inch of lift. Looking to buy replacements and was thinking about these. Thoughts, opinions and measurements if you have them please.
mtbiker is offline   Reply With Quote Quick reply to this message
Unread 04-27-2015, 06:33 PM   #2
Drednot
Drednot's Avatar
I have them. They said 2.5" on them, but they started out at 3" of lift when installed. They haven't sagged any that i can notice in almost 3 years and 30k miles. I did install bumpstop extensions, though, which is necessary to keep from crushing the coils.
Measures 21 3/4" from wheel center to edge of flare. It was 18 something stock.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote Quick reply to this message
Unread 04-27-2015, 07:07 PM   #3
mtbiker
2011 KK Liberty
Did you use any additional isos? My Lib has had a lean since I had the lift installed. I was thinking of adding one extra on top on the Drivers side to try & level it out.
Unread 04-27-2015, 07:08 PM   #4
mtbiker
2011 KK Liberty
PS: I ordered 4 pucks last night. I plan to do it right this time!
Unread 04-28-2015, 07:32 PM   #5
mtbiker
2011 KK Liberty
Springs are on the way. Drednot, did you use any additional isos?
Unread 05-01-2015, 08:28 PM   #6
Drednot
Drednot's Avatar
Sorry, no, I did not. No lean. I have the adjust-a-struts, so its easy to make level.
"Non Vi Sed, Arte"
Unread 05-01-2015, 08:34 PM   #7
mtbiker
2011 KK Liberty
Awesome! Thanks for the help/info. I got my new springs, new shocks,pucks & I picked up some new tools to make the install a little easier. Just gotta pick up the hardware & I should get them installed Sunday hopefully. My lean was pretty significant. Prob gonna add one Iso to the drivers side.
Unread 05-02-2015, 03:04 AM   #8
Drednot
Drednot's Avatar
Heres some pics
"Non Vi Sed, Arte"
Unread 05-02-2015, 05:05 PM   #9
mtbiker
2011 KK Liberty
It's all done. Turned out pretty good. It's tall right now. I'm @ 22", bit I left the spare off because I need to replace it (dry rotted to Hell, glad I never needed it & found out before it was too late) & I'm on Empty. Definitely rides firmer than it did.
Unread 05-02-2015, 07:45 PM   #10
Bmxer524
2011 KK Liberty
22" with the 2.5" springs, correct?
2011 Deep Cherry Red KK - Skyslider - OME 927/731 - Bilstein Shocks - 1/4" Spacer Plate - 3/8" Clevis - Al's A-arms - 245/75-16 Duratracs
Bmxer524 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2015, 07:46 PM   #11
mtbiker
2011 KK Liberty
Correct, just the JBA 2.5" springs.
Unread 05-02-2015, 07:48 PM   #12
Bmxer524
2011 KK Liberty
Hmmm, I may have to play around with my JBA springs then....
Unread 05-02-2015, 07:56 PM   #13
mtbiker
2011 KK Liberty
I put them on & added the Monroe load adjusting shocks that tommudd suggested. I carry a good bit of stuff & travel alot loaded. Was looking for a way to avoid that *** dragging look.
Unread 05-02-2015, 11:02 PM   #14
tommudd
2004 KJ Liberty
mtbiker, You're getting some lift from the shocks as well ( only case where shocks will give you a little bit more lift)
04 Liberty, Kilimanjaro Edition, Rock Lizard RockRails/Roof Rack/Front-Rear bumper,32 inch Goodyear Duratracs,Moabs,4.10s/ 4.25 inch JBA Coilover lift /other goodies
tommudd is offline   Reply With Quote Quick reply to this message
Unread 05-03-2015, 06:57 AM   #15
mtbiker
2011 KK Liberty
There was a pretty big difference between my OME 731s and the JBA 2.5" springs. Second pic is just about ready to put the new coils in place.
