How to replace driver's side headlight bulb? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > How to replace driver's side headlight bulb?
Tactical Recovery Equipment Soft Shackles!!!50% Off Sale at KrawlOff-Road.com50" LED CREE Light Bar Pair With Wiring Kit
Unread 05-12-2011, 07:19 PM   #1
jleighhester
2008 KK Liberty
So... I have a 2008 Jeep Liberty. The regular beam headlight bulb burnt out. I bought a new one... however, I'm apparently not mechanically inclined...
Could someone break down the directions for replacing the bulb in a first grade level?
Thanks so much.
jleighhester is offline   Reply With Quote Quick reply to this message
Unread 05-14-2011, 04:39 PM   #2
SuperRliBerty
2008 KK Liberty
will post it for you tomorrow......
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline   Reply With Quote Quick reply to this message
Unread 05-14-2011, 07:05 PM   #3
alex725
2009 XK Commander
stick your hand in and turn? I swapped mine out and I remember there was something special you had to do with pushing tabs or something to that effect once you took the bulb out of the housing.
alex725 is offline   Reply With Quote Quick reply to this message
Unread 05-15-2011, 12:27 PM   #4
SuperRliBerty
2008 KK Liberty
1. Remove the battery. THIS IS OPTIONAL! I remove it to gain better access to the bulb connector. (nuts are 12mm)
2.Remove the 10mm battery "tie down" bolt. ( arrow)
3. Headlight bulb connector (green)
4. Grab hold of tabs ( yellow arrow) AND TURN COUNTER CLOCKWISE, pull towards you.
5. Pull out red tab on connector to remove bulb. When installing new bulb, DO NOT HANDLE GLASS END OF BULB!
Steps 4 thru 1 for re-installation
2008 Sport Liberty
Unread 05-15-2011, 04:12 PM   #5
Telerock
2010 KK Liberty
Wow! This is super helpful. I shouldn't have to replace mine for a long time, but bookmarked this thread for when I do!
Telerock is offline   Reply With Quote Quick reply to this message
Unread 05-15-2011, 07:24 PM   #6
SuperRliBerty
2008 KK Liberty
I upgraded to sylvania super whites
2008 Sport Liberty
Unread 05-15-2011, 07:25 PM   #7
SuperRliBerty
2008 KK Liberty
Removal of the foglight bulbs are the same for the headlights
2008 Sport Liberty
Unread 05-17-2011, 05:29 PM   #8
jleighhester
2008 KK Liberty
Awesome! Thank you so much for the detailed instruction.
Unread 01-17-2012, 06:34 PM   #9
ijeepca
2010 KK Liberty
One very important thing to add
Be sure to remove the "old" "O ring" from the original light bulb or the new light won't fit.
Thank you for writing out all the instructions they were very helpful.
My websites: ijeep.ca and myjeep.ca
***Websites are currently under repair and I could sell a domain name if the price is right
ijeepca is offline   Reply With Quote Quick reply to this message
Unread 01-17-2012, 07:34 PM   #10
Skipper6413
2011 KK Liberty
How do you like the super whites?
Skipper6413 is offline   Reply With Quote Quick reply to this message
Unread 01-18-2012, 02:10 PM   #11
BloodyShadow23
2008 KK Liberty
But the fog lights seem WAY harder to reach. Is there an easier way to replace those?
2008 Liberty Sport - Chrome Grill, K&N CAI,
BloodyShadow23 is offline   Reply With Quote Quick reply to this message
Unread 01-18-2012, 04:16 PM   #12
Eagle112199
2008 KK Liberty
I too got the super white lights - they are a lot better then stock lights. Many reviews of the Liberty cite that as a con and I can agree - I burned the fog lights all the time until I got the new bulbs. It is worth the investment.
"Jeep - not a passion; it is an obsession"
Eagle112199 is offline   Reply With Quote Quick reply to this message
Unread 01-18-2012, 10:44 PM   #13
SuperRliBerty
2008 KK Liberty
Bright and nice for a couple if months ...... Now they are somewhat dull like the factory bulbs
2008 Sport Liberty
Unread 01-18-2012, 10:47 PM   #14
SuperRliBerty
2008 KK Liberty
The driver side, remove the battery and the fog lights can be easily removed
2008 Sport Liberty
Unread 01-21-2012, 04:44 PM   #15
Sagerist
Sagerist's Avatar
Just have to say, that was the EASIEST thing i have ever done on a car. took me 3 minutes to get the new headlights bulbs switched. I did my fiancés subaru impreza and that required taking off the front bumper and removing the whole headlight assembly just to reach the bulbs:brick wall. Now i have the silverstar ultras and i did the drivers side first and looked at the difference between the two bulbs and you can definitely see that the ultras are brighter and not as yellow. can't wait to test them in the snow storm we are about to get here tonight!
Colorado Jeep Club Member #286
89 YJ 2.5L
OME 36R's, Bilstein 5100's, Bserk 5/8" shackles, 33x10.5 BFG's on 15x8
09 KK Sport 4X4
235/75/16 GY Slnt Armor
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline   Reply With Quote Quick reply to this message
