While pouring oil in my '08 libby, I bumped my head ( I am 6ft1) The hood is very heavy I noticed on my girlfriend's taurus the hood opened wide and was supported by struts.:idea:
I went to the local salvage yard, found a '95 taurus, removed the hood struts. $30
Installed them on my Libby, now she opens wide as the grand canyon and close gently. Stays open during windy conditions
If you want to do this mod, $30 plus shipping and handling, includes struts, hardware and instructions. If you going rogue and want to buy it yourself, buy heavy duty hood struts and be careful. It is easy check out the pics.
Great! To all liberty owners, If you spend time under the hood, I strongly suggest this mod, because after you hit your head on hood, that mod will be welcomed.
I submitted the pics to a local chrysler dealer here and I got no response. I want to suggest it to chrysler and hope they can implement it on ALL JEEPs
ELT3198, there were holes already drilled from the factory. Is it possible that chrysler R&D folks wanted to add a hood strut? The hood is quite heavy. I mounted the ball joint in the existing drilled holes and secured the struts, 15 minutes.
Interesting, its possible they were going to do it then decided not to, to save money maybe. The KK is VERY heavy compared to a lot of other vehicles Ive opened the hood on.
My next door neighbor sold his '98 cadillac sevillle to a salvage company. Whilst he was waiting for them to tow it away, I peaked under the hood, and noticed the hood opened wide like a big mouth bass, had an :idea:
I swapped his longer hood struts for my ford taurus hood struts.:2thumbsup: took less than 5 minutes to swap. I got about 5 degrees more hood angle opening.
That looks like the second thing I do under the hood. What CIA are you using? I also see a shiny breather filter, which brand is it? Having hard time finding anything other than MOPAR intake...too many $$$ right now.
Thanks
I purchased a 9"X4" filter ($42) and a 3" ($2.99) breather filter and installed it ..... felt a bit of responsive. I installed the Dynomax thrush turbo muffler, and noticed a huge difference in throttle response
Got a post card from satan (http://www.hollywoodchryslerjeep.com/index.htm)for an oil change $19.99. Give the guy my keys and the post card, he told me to go wait in the lounge. Sat there for about 10 minutes before I saw my libby drove into the bay. I walked back there to the bay to see mike the mechanic open the hood and looked for the hood prop.
For a few seconds he was baffled, then he saw the hood prop and released the hood...lol....
I'm preparing to do my hood mod. I forgot to get some nuts for the struts, so I'll have to go back before I can install. These were bought from autozone and are exactly 19 1/4 inch long, and you can get the model number in the pic too. Both ends have ball joints, and it looks to match up pretty good. Only 1 hole to drill to mount bottom of strut. They seem pretty beefy and were like $19 a piece. Once I get my nuts (lol), I'll post my install pics.
Oh yeah, autozone struts weren't a great selection, and my choice was based on what would work best with ball joints and i wished they were a bit longer. I think around 22 inches would have pushed the struts back to the factory holes and provide adequate hood angle. But like I said, their selection wasnt great and I was checking to make sure fittings would work.
Ok. Finished the mod. Mine could have been better because: actual travel distance of strut was kind of short, thus hood raised a tad under what the rod gave you. I figured it might be an issue when i got them, but not much selection to really pick from and I wanted ball joints. But struts work great and mod was ok besides that one issue. I'm happy.
Ponch: I didn't need anything else. Except a good prod for the grill with my old hood rod! Works great. Only issue I had was the length which I knew would be shorter. But like I said, the store didn't have the longer ones.
Back on page one they used strut from a 98 Cadillac Seville. I didn't want to use used struts.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
