Hood Prop Mod - Page 2 - JeepForum.com
post #16 of 64 Old 11-22-2011, 08:39 PM
Deichler
2008 KK Liberty
Could you measure those struts in full length? I want to do this and want to know what length to get. Thanks!!
Deichler is offline
post #17 of 64 Old 11-24-2011, 06:01 PM Thread Starter
SuperRliBerty
2008 KK Liberty
I original ones were from a '98 ford taurus at the salvage yard. Those in the pics are from a 2000 cadillac eldorado.
The cadillac hood opens wider. Remove it along with the ball pin.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #18 of 64 Old 12-02-2011, 10:31 AM
musclezmarinara
2012 KK Liberty
any update on the size of those struts?
2012 KK Cherokee * Arctic * Mineral Gray
- Mods - See Build Thread..
musclezmarinara is offline
post #19 of 64 Old 05-05-2012, 10:16 PM
Skipper6413
2011 KK Liberty
Click image for larger version
I'm preparing to do my hood mod. I forgot to get some nuts for the struts, so I'll have to go back before I can install. These were bought from autozone and are exactly 19 1/4 inch long, and you can get the model number in the pic too. Both ends have ball joints, and it looks to match up pretty good. Only 1 hole to drill to mount bottom of strut. They seem pretty beefy and were like $19 a piece. Once I get my nuts (lol), I'll post my install pics.
Skipper6413 is offline
post #20 of 64 Old 05-05-2012, 10:26 PM
Skipper6413
2011 KK Liberty
Oh yeah, autozone struts weren't a great selection, and my choice was based on what would work best with ball joints and i wished they were a bit longer. I think around 22 inches would have pushed the struts back to the factory holes and provide adequate hood angle. But like I said, their selection wasnt great and I was checking to make sure fittings would work.
post #21 of 64 Old 05-08-2012, 06:34 PM
Skipper6413
2011 KK Liberty
Ok. Finished the mod. Mine could have been better because: actual travel distance of strut was kind of short, thus hood raised a tad under what the rod gave you. I figured it might be an issue when i got them, but not much selection to really pick from and I wanted ball joints. But struts work great and mod was ok besides that one issue. I'm happy.
post #22 of 64 Old 05-20-2012, 11:42 AM Thread Starter
SuperRliBerty
2008 KK Liberty
Skipper, can you post pics of the install? I went with the struts off a 2002 cadillac. The hood open wide enough.
2008 Sport Liberty
post #23 of 64 Old 10-14-2012, 07:53 PM
Skipper6413
2011 KK Liberty
post #24 of 64 Old 10-14-2012, 07:53 PM
Skipper6413
2011 KK Liberty
Sorry so long. Had to move.
post #25 of 64 Old 10-14-2012, 10:40 PM
Poncherello
2010 KK Liberty
So I if I drive to a local Salvage yard , picking up a pair of struts from a Caddy is the best thing to do? Will I need anything else?
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #26 of 64 Old 10-15-2012, 02:51 AM
fairmont1998
2012 KK Liberty
Originally Posted by SuperRliBerty View Post
ELT3198, there were holes already drilled from the factory. Is it possible that chrysler R&D folks wanted to add a hood strut? The hood is quite heavy. I mounted the ball joint in the existing drilled holes and secured the struts, 15 minutes.
They actually had struts fitted for use during production, then they remove them before the car comes off the line. Noticed in some videos of the Liberty plant on YouTube. At least that leaves us with the perfect holes to mount struts to down the track.
2012 KK Cherokee Limited CRD
fairmont1998 is offline
post #27 of 64 Old 10-15-2012, 10:17 PM
Skipper6413
2011 KK Liberty
Ponch: I didn't need anything else. Except a good prod for the grill with my old hood rod! Works great. Only issue I had was the length which I knew would be shorter. But like I said, the store didn't have the longer ones.
post #28 of 64 Old 10-16-2012, 07:33 AM
DeltaForceB85
2008 KK Liberty
I am so going to the junkyard tomorrow.
-Josh
2008 Jeep Liberty KK W/Selec Trac II, ADL Skid Plate Group, 245/70/16 All Terrain Destinations, VisionX LED Floodlights. It's a real jeep. Don't like it? Wait let me check. Yep, still a real jeep.
DeltaForceB85 is offline
post #29 of 64 Old 10-16-2012, 08:59 AM
jsburton84
2008 KK Liberty
My next door neighbor sold his '98 cadillac sevillle to a salvage company. Whilst he was waiting for them to tow it away, I peaked under the hood, and noticed the hood opened wide like a big mouth bass, had an
I swapped his longer hood struts for my ford taurus hood struts. took less than 5 minutes to swap. I got about 5 degrees more hood angle opening.
I'm a bit confused, what year and model caddy struts fit the best?
2008 KK sport 4x4
1998 XJ sport 4x4 (sold)
jsburton84 is offline
post #30 of 64 Old 10-16-2012, 05:55 PM
Skipper6413
2011 KK Liberty
Back on page one they used strut from a 98 Cadillac Seville. I didn't want to use used struts.
