Holy Smokes! Oil Filter Trick Works - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Holy Smokes! Oil Filter Trick Works
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-05-2015, 04:12 PM   #1
josworth
2010 KK Liberty
Figured I'd put it out there in a thread of it's own instead of burying it one of the countless oil filter threads out there.
For those of us that have a real hard time getting at the darn oil filter without busting up our arms or making a real mess of things.....
It was mentioned that you could take out the driver's side headlamp for easier access to the filter.
I was intrigued but skeptical. So, yesterday I did it...
WOOHOO! It made my oil change a breeze! No jack, no ramps, just a drain pan, and a socket wrench.
Seriously, the grill pops out easy after pulling out the little plastic rivets. Then the headlamp comes out by removing three torx screws.
After that, you can just reach in to the space and the filter is right there. Great leverage as well. I was able to remove it and replace it by hand without any worries if it was tight enough or not.
Here is what it looks like....
Not zoomed... just moved my phone closer..
So, for those that struggle with the darn filter.. it is worth the 10 minutes it takes to pull the grill and headlamp.
Jeff
2010 Jeep Liberty Limited
josworth is offline   Reply With Quote Quick reply to this message
Unread 01-05-2015, 08:53 PM   #2
lfhoward
2008 KK Liberty
Nice going! This thread is going to help tons of folks. If you duplicate it over on LOST, I'll link it in the KK how-to's index.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 12:03 PM   #3
Gageraid
2008 KK Liberty
I'd like to try this as well one day.
I just did an oil change using the crawl under the Jeep and lay on your back with a flashlight method.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 02:52 PM   #4
josworth
2010 KK Liberty
Seriously, it makes the change cake...
@lfhoward.. I will copy this over to lost.....
Jeff
Unread 01-11-2015, 05:29 AM   #5
97_JGC
Thanks for this info. I was not looking forward to my first oil change on a "new to us" 2010 trail rated.
97_JGC is offline   Reply With Quote Quick reply to this message
Unread 01-17-2015, 02:14 PM   #6
mighty4banger
Nice tip - I just tried this today... the other big win is that you can ensure you get the new filter on tight enough! Up until this tip I was considering doing a relocation kit for the filter.
95 YJ 2.5L 5 speed, 4.88's, Aussie Locker D30, 35" Mud Rovers, Herculined tub, TKH rear bumper, Ford 8.8, JB Conv. SYE, Sylvania Silver Stars, T-MAX 9K winch, MORE 1" body lift, Turbo City oil pan skid, Rubicon Express 4" lift...
2012 KK Black all stock.
mighty4banger is offline   Reply With Quote Quick reply to this message
Unread 01-17-2015, 04:13 PM   #7
Dave_B
2008 KK Liberty
Seems like a lot of extra work, just reach in put a end cap filter wrench on a long extention go in from the front. Straight shot your done before the grill is out. Or $64.99 and let Jeep do it 4 times.
Dave
Dave_B is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 01:04 PM   #8
josworth
2010 KK Liberty
LOL.... I too mentioned a relocation kit... I even asked for some help from the custom builders I used to deal with on LXForums when I had the Hemi 300. It was just to expensive to do it right with the kind of parts that would last a life time of daily use. Now, it doesn't matter....
Dave
Funny, I tried that but couldn't get it to work. The filter is mounted at an angle and on my Liberty it isn't a clear shot up from the bottom. Maybe some pictures showing how it is done when you do it next? If it is better, show us...
Last time I paid my dealer to change the oil they insisted they did it even after I said they didn't based on the color of the oil. Not until I asked them if they suddenly started using Bosch filters did they admit their mistake..... so, no matter how cheap, no thanks... I prefer to do my own service.
Like I said in my original post.... for some they seem to have an easy time of it, for others it is always a royal PIA. I tried layin under it in different directions, using an extension and filter socket, even took the plastic drain channel off, but it always was a major pain to get my thick arms up in there to get it off. Taking the grill out is super easy, and actually made my total oil change time a whole lot quicker since I am not using ramps or a jack/stands anymore...
Jeff
Unread Today, 09:32 AM   #9
DrD28
I was wondering how often to change synthetic oil. The owners Manuel says 5 thousand miles. Any thoughts
DrD28 is offline   Reply With Quote Quick reply to this message
