HELP! Leak and rattle above the headliner! - JeepForum.com
post #1 of 6 Old 11-17-2013, 10:34 AM Thread Starter
pakman325
Got in the car just now to head to the hardware store and I saw one of the trim pieces above the liftgate dump about a half cup of water onto my cargo mat.
She's usually garage kept but I was doing some home improvement work and left the kk in the driveway last night in the rain.
Today as I drive it, I could hear a rattling above the passenger C pillar.
Any idea where I should start?
pakman325 is offline
post #2 of 6 Old 11-17-2013, 08:44 PM
lfhoward
2008 KK Liberty
I am not sure about the rattle but I had a similar leak in my '08. According to what I've read, this could either be a leak around your roof rack bolts, or water is getting under the rubber seal around your hatch door. In my case it was the latter. I pulled the rubber seal off from about 9:00 to 3:00 (if you think of the hatch opening as a clock face), and then used a good amount of RTV silicone to seal it back on. I did check the roof studs and the welds around the hatch too though. You can pull off that center trim piece by pulling down in the center. Once the metal clips disengage, you can dislodge the tabs on the left and right sides and take it off (the half cup of water pools in this trim piece, by the way). From there you can see above the headliner with a flashlight and see if water is coming in through the roof rack stud area. Good luck!
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #3 of 6 Old 11-18-2013, 08:05 AM Thread Starter
pakman325
Thanks. After looking at it a little more closely, there was a messed up weatherstripping on the rear passenger door. It kinked and didn't sit right when the door closed and the sound was buffeting in the wind. Now to clean the headliner...
post #4 of 6 Old 04-08-2014, 01:10 PM Thread Starter
pakman325
I didn't update this for a while, but it's definitely still an issue. I'm at my freaking wit's end with this same leak. Even though I thought it was earlier, mine was decidedly not the weatherstripping seal around the liftgate opening, which seems to have been documented elsewhere. I thought that could have been it after I generously reapplied sealant to that seal, but after a huge rainstorm I got the biggest puddle of water on my trunk mat that I had ever seen. Maybe 10-12 ounces.
I'm now thinking it could be the roof rails. How would I go about disassembling them and applying RTV sealant to them?
Also, what do I need to do to limit rusting in between the frame panels? I have seen small amounts of it when trying to trace the leak.
post #5 of 6 Old 07-28-2014, 10:30 PM
Lanman526
Originally Posted by pakman325
I didn't update this for a while, but it's definitely still an issue. I'm at my freaking wit's end with this same leak. Even though I thought it was earlier, mine was decidedly not the weatherstripping seal around the liftgate opening, which seems to have been documented elsewhere. I thought that could have been it after I generously reapplied sealant to that seal, but after a huge rainstorm I got the biggest puddle of water on my trunk mat that I had ever seen. Maybe 10-12 ounces. I'm now thinking it could be the roof rails. How would I go about disassembling them and applying RTV sealant to them? Also, what do I need to do to limit rusting in between the frame panels? I have seen small amounts of it when trying to trace the leak.
I just came across this looking for help with a different water leak. Not sure if it's still any worry to you...I had water leaking in the same spot and it was coming in easily. I located my leak to be the wielded seal around the frame of the tailgate where the bracket is bolted for the lift gate. Mine was even on the same side. I bought some cheap sealer putty and it hasn't been a problem since. I could add photos if it'd help.
Now, I got to fix the other water leak.
Lanman526 is offline
post #6 of 6 Old 07-30-2014, 10:01 AM Thread Starter
pakman325
It's definitely still an issue for me. And I have an issue with the TIPM that may be independent which at this moment means no A/C.
My daughter was born in May, so the jeep was essentially just garage kept through the summer. Still have to get it sorted out...
