Help: jeep liberty 2009 8" ROOF antenna NEEDED - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Help: jeep liberty 2009 8" ROOF antenna NEEDED
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBds fox ipf 2.0 racing series shocks now available at rockSpartan Lockers FREE SHIPPING Excellent Prices
Unread 01-10-2010, 08:05 AM   #1
bobbarto
As my garage door was opening, I (snapped off the screw part of the antenna) on my jeep liberty. It's the 8 inch screw-in antenna and I been searching all over the internet and can't find one.
Maybe it's because I'm not using the correct wording or don't have a part number.
Can someone help me out?
Also, it looks like I will need a special tool to remove the top part of the antenna housing?
Thanks So Much,
Bobbarto
bobbarto is offline   Reply With Quote
Unread 01-10-2010, 09:13 AM   #2
Busch2fan
2008 KK Liberty
Can't help but the least you could have done is blamed it on your wife.
Busch2fan is offline   Reply With Quote
Unread 01-10-2010, 03:09 PM   #3
Elt31987
Elt31987's Avatar
2008 KK Liberty
Go to Jeep Liberty Parts - The Official Jeep Parts eStore offered by Chrysler , Go to electrical, go to Radio, Antenna, Speakers, DVD, and ..., then go to antenna. Maybe that will help
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline   Reply With Quote
Unread 01-10-2010, 05:02 PM   #4
ColdCase
ColdCase's Avatar
2011 WK
If you are talking about the mast, I purchases a slightly shorter universal version (one with several thread adapters) off eBay for my 09. Shorter means a little less signal, but it does not hang up in my garage door. They are a fairly standard screw in thread, no tools needed. Guys at the garage routinely unscrew them when working on the car... err.. sorry... jeep :-).
Tearing them off is common.
Mangowalk 5" Black Short & Stubby Rubber Antenna Mast, about $13 with shipping.
Mangowalk 5" Black Short & Stubby Rubber Antenna Mast:eBay Motors (item 350175850793 end time Feb-01-10 18:32:51 PST)
Where did yours snap off? Near the base?
ColdCase is offline   Reply With Quote
Unread 01-10-2010, 06:34 PM   #5
bobbarto
It snap off by the screw
It snap off at the screw, the screw broke in 1/2.
1/2 of the screw is in the Base and the other 1/2 is in the Antenna.
Bobbarto
Unread 01-10-2010, 06:59 PM   #6
ColdCase
ColdCase's Avatar
2011 WK
That 1/2 screw may be a PITA to get out. If you can't grab what is left of the screw, you may need to use a small drill and easy out. You won't be able to get at it from under the cap. Perhaps there will be enough friction between the broken parts to ease it out, they are not that tight. I'm sure the dealer or a stereo installer has dealt with many of these
Unread 01-10-2010, 08:42 PM   #7
diggerfreek
2008 KK Liberty
5064253AB MAST, Antenna
diggerfreek is offline   Reply With Quote
Unread 01-11-2010, 03:56 AM   #8
bobbarto
I did a search for 5064253AB
and no luck, can you point me to the site..Thanks
5064253ab mast, antenna
Unread 01-11-2010, 05:08 AM   #9
Elt31987
Elt31987's Avatar
2008 KK Liberty
Same site i sent you in the earlier post.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Unread 01-11-2010, 09:26 AM   #10
diggerfreek
2008 KK Liberty
These guys have it for $3.66, but you will probably pay 10 bucks for shipping....
WWW.SPRINTERPARTS.NET - For ALL your Sprinter Parts Needs!
These guys have it for $2.99, but again, shipping...
Jeep Parts | Dodge Parts | Chrysler Parts - Don't Fear the Jeeper offers OEM parts and accessories for Chrysler Jeep and Dodge vehicles including 2005 2006 2007 2008 and 2009 models
Unread 01-11-2010, 02:53 PM   #11
bobbarto
Elt31987 I order two..Thanks
Thanks...I order two...just in case.
From User Elt31987. Go to Jeep Liberty Parts - The Official Jeep Parts eStore offered by Chrysler , Go to electrical, go to Radio, Antenna, Speakers, DVD, and ..., then go to antenna.
Bobbarto
Unread 01-11-2010, 02:59 PM   #12
bobbarto
I just realize 1/2 screw broken in the base?
How do I remove the 1/2 screw?
PS...I did order the two Antennas.
Thanks,
bobbarto
Unread 01-11-2010, 03:03 PM   #13
diggerfreek
2008 KK Liberty
Using a left handed drill bit would probably be best. If not, you can then is a easy out to get it out
Unread 01-11-2010, 05:41 PM   #14
bobbarto
Ok I will try it this weekend
Ok, I will give it a try this weekend removing the broken screw in the base.
Thanks,
Bobbarto
Unread 01-12-2010, 05:25 AM   #15
bobbarto
How about buying screw tap
If I purchase a screw tap, I can tap out the screw and back it out.
Bobbarto
