Help disassemble TIPM - JeepForum.com
post #1 of 3 Old 06-07-2013, 03:24 PM Thread Starter
RKK
2012 KK Liberty
I need to open this and inspect flood damaged tp from my Jeep kk 2012. Any ideas?
RKK is offline
post #2 of 3 Old 06-07-2013, 05:13 PM
AtTheHelm
There are four clips holding it in on the corners. Undo those and the power cable (yellow?).
Lift up the tipm and disconnect the harnesses underneath.
AtTheHelm is offline
post #3 of 3 Old 06-08-2013, 04:24 PM Thread Starter
RKK
2012 KK Liberty
I removed TIPM by pressing the 4 tabs and disconnecting the wiring harness to TIPM. I wanted to open the plastic case and look at the PCB. ronjenx wrote an excellent article about TIPM TIPM http://www.jeepforum.com/forum/f96/o...study-1200238/ and he disassembled all the PCB, however I am not able to do the same. There are several latches needs to be unlocked at the same time. It is hard to unlock without damaging the TIPM. So I was wondering if anyone out there successfully opened TIPM and put it back in working condition? Are there any special tools out there to open up the plastic case?
RKK is offline
