Help with back glass on lift gate - Page 3 - JeepForum.com
post #31 of 42 Old 12-24-2013, 09:21 PM
marlon_jbt
2010 KK Liberty
You guys are making me really nervous.
Red Jeep Club member # 264
marlon_jbt is offline
post #32 of 42 Old 01-15-2014, 04:55 PM
james2003e
I have read through this thread, these hinges are very frustrating. Today I went to the dealer and was told I would have to buy the glass also, because the tabs are attached to the glass. So for clarification, can the hinges indeed be bought separately, mine is a 2008 model. Thank You
james2003e is offline
post #33 of 42 Old 01-15-2014, 05:56 PM
athomasg
2010 KK Liberty
After reading through this thread it appears that the
driver side hinge is part# 57010061AB
and the
passenger side hinge is part# 57010060AB
'10 KK Liberty Renegade *White*
K&N CAI
'00 Cherokee XJ *White*
4.5" RC lift, 33x12.5 GY DuraTrac
athomasg is offline
post #34 of 42 Old 01-17-2014, 11:55 PM
cherokeeshrop91
2009 KK Liberty
hey guys,
was just looking through this post, and had a question i hope someone can answer even though this has not happened to me. on the older model liberty's, i believe the back glass came with hinges that had a drain hole in the bottom of them to prevent this problem. has anyone thought of attempting to use the older style hinges? if so would they fit? i figure if you could get them either from dealer or wherever else, it would be a great mod to make sure that this issue plenty seem to be having does not happen again. i have not researched whether the older liberty's had this problem or not so please correct me if i'm wrong. thanks.
-R.I.P 96 XJ 4x4 w/ 4.5 R.C lift,
& 33/12.50/15 M/T's mostly built.
-Current 2009 Jeep Liberty KK 4x4,
stock but not for long.
cherokeeshrop91 is offline
post #35 of 42 Old 01-19-2014, 09:36 AM
adammillers
The old style hinges are very different in shape and style. They will definitely not work for the new style Jeep liberty. I ordered a pair of them on accident to fix my problem and I had to send them back.
adammillers is offline
post #36 of 42 Old 01-20-2014, 01:09 PM
jonner519
Guys:
I can confirm that I ordered just the hinges for the 2008 Jeep Liberty and that is it. You absolutely do not need to order the entire rear glass assembly.
My right one completely rusted out and separated from the glass (like some of the pictures in this thread) and then upon closer inspection the left was close to going as well so I ordered a hinge for both sides.
I think there is confusion with respect to the inventory @ Jeep b/c when I went to order them the guy @ the inventory counter at the Jeep dealership originally said to me as well that I needed to order the entire glass assembly ($1K). Which, of course, I thought was crazy and did more reserach and thankfully found this thread.
I think it turns out that for some reason in the inventory Jeep only has hinges for 2007 and 2009+ models (but not 2008). Since 2008 and 2009 are the same model I ordered the 2009 hinges and worked fine. So try asking for hinges for the 2009 model if you are getting the run around on the 2008 model.
Cheers
jonner519 is offline
post #37 of 42 Old 02-15-2014, 09:16 PM
smedcat
2008 KK Liberty
My 2008 Liberty did the same thing. After getting the run around from the window guys, body shops, salvage yards, and most of all the dealership I did find them online. Go to Mopar.com, enter your jeep year, body style, ect, then shop parts. On the left side of the screen it will give you parts/accessories list. The hinges can be found under the glass heading. They are $39.10 on this site but once I found the part number, I did a google search of that and found a couple sites that sell them a little cheaper. Hope this is helpful for you and to anyone else that may come across this same issue!
smedcat is offline
post #38 of 42 Old 02-15-2014, 10:44 PM
Yakker
2008 KK Liberty
Hey smedcat,thanx for the post-we're almost neighbors(except for that big bridge over the Detroit river) we're both living thru the same cold crappy tons-of-salt-on-the-roads winter.Would have thought these hinges should have held up better but my right side one is really bad-will def have to replace it in the spring.Spring is coming eh? or is this the next ice age just starting?
Blacked out headlights,Mopar hitch,255/70/16 AT2s,racks for the yaks-missing front air dam since a wild ride in Wyoming in 2010
Yakker is offline
post #39 of 42 Old 02-21-2014, 11:00 AM
longman
2014 JK Wrangler
Wow ...same issue here with my wife's new-to-her '08 KK. Bought from a dealer and it has to go back to install a missing grill piece, so after reading this, I am going to be rather insistent that they fix this hinge issue also. I thought it was just a cosmetic thing, but now, after seeing the "fix pix" ... just sayin. Thanks to the posters on this :-)
longman is offline
post #40 of 42 Old 02-22-2014, 05:03 PM
Yakker
2008 KK Liberty
If you're seeing the cracks in the hinge that we've got then really push them to fix it. Good luck,hope it works out.
Yakker is offline
post #41 of 42 Old 07-01-2014, 02:13 PM
slm007il
GREETINGS JEEP LOVERS. I have just purchased and have in my possesion both flipper hinges for my 2008 Jeep liberty rear hatch glass. YOU DO NOT HAVE TO BUY A NEW WINDOW. The same part should work through 2012. The mopar numbers are RH HINGE-GLASS part # 57010060AB cost 26.26 - 39.10, LH HINGE-GLASS part # 57010061AB cost 26.26 - 39.10 The best price found is at http://allmoparparts.com
$26.26 each plus shipping. Best Regards Steve M. Shelbyville IL
slm007il is offline
post #42 of 42 Old 07-05-2016, 03:46 PM
AJB8891
i found them on good for like $56ish. hope this helps im having the same issues only the latch broke off the glass and not off the car. HELP!! i just need a quick fix until i can get enough money to properly fix it.
AJB8891 is offline
