Help 2012 Jeep liberty - JeepForum.com
post #1 of 12 Old 01-09-2014, 06:51 AM Thread Starter
war2eagle
I recently bought a 2012 jeep liberty limited. 43000k it's runs great. We just had about 2 feet of snow in 3 days roads were real icy and to run in 4 wheel lock a few times (drove real slow). However even if I'm in 4wd lock or 2 WD when I turn it makes a grinding noise. Is this normal? It only does when I turn and the sharper I turn the worse it sounds. Makes no noise when driving straight. Just wondering if anyone has had similar issue.
war2eagle is offline
post #2 of 12 Old 01-09-2014, 07:16 AM
LKWJEEPER
2009 KK Liberty
Possibly a bad CV joint?
If I were you I'd get it checked out asap.
Sent from AutoGuide.com Free App
LKWJEEPER is offline
post #3 of 12 Old 01-09-2014, 08:43 AM
NXVash
2012 KK Liberty
I have noticed this in my 2012 sport, Every time I notice it though its when there is snow on the ground and thats what is causing the noise. Hope that helps.
NXVash is offline
post #4 of 12 Old 01-09-2014, 09:25 AM
98ZJ SFD
2012 KK Liberty
Is your traction control kicking in?
Current
2012 KK Sport, Mopar skids, DuraTracs, Mopar Grille Guard
Previous
98 ZJ Laredo SE 4.0, 2" Skyjacker BB, JKS Quicker Discos, Goodyear Wrangler MT/Rs, K&N FIPK, Kolak cat & back exhaust, Westin Safari bar, KC lights
98ZJ SFD is offline
post #5 of 12 Old 01-09-2014, 09:36 AM
Babaki
2012 KK Liberty
sound like traction control to me. it makes a horrid noise if you arent used to that sound
Babaki is offline
post #6 of 12 Old 01-09-2014, 11:36 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Do you see any lights?
from the owner manual:
The “ESC Activation/Malfunction Indicator Light” located
in the instrument cluster will start to flash as soon
as the tires lose traction and the ESC system becomes
active. The “ESC Activation/Malfunction Indicator
Light” also flashes when the TCS is active. If the “ESC
Activation/Malfunction Indicator Light” begins to flash
during acceleration, ease up on the accelerator and apply
as little throttle as possible. Be sure to adapt your speed
and driving to the prevailing road conditions.
Things to note:
• The “ESC Activation/Malfunction Indicator Light”
and the “ESC OFF Indicator Light” come on momentarily
each time the ignition switch is turned ON.
• Each time the ignition is turned ON, the ESC system
will be ON even if it was turned off previously.
• The ESC system will make buzzing or clicking sounds
when it is active. This is normal; the sounds will stop
when ESC becomes inactive following the maneuver
that caused the ESC activation.
JeepCares is online now
post #7 of 12 Old 01-09-2014, 05:58 PM Thread Starter
war2eagle
No lights. Roads cleared today and it doesn't do it unless snowy road. Which I guess would point to traction control?
post #8 of 12 Old 01-09-2014, 06:13 PM
Gageraid
2008 KK Liberty
Most likely. I'm sure others will agree, but the smallest piece of ice can set of the traction control. Heck, it was turning on for me the other night when I didn't even know there was still ice in my driveway as I reversed into my spot.
It is a noise you have to get used to, but it's just how the system works.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #9 of 12 Old 01-10-2014, 01:20 PM
Jeepers20
2012 KK Liberty
The symbol will light up on the dash when the traction control kicks in, its a pic of a jeep with swerve marks. Its probably what your hearing, but look for that symbol next time.
Jeepers20 is offline
post #10 of 12 Old 01-11-2014, 12:45 AM
xxxxxxxxxxxxSmetna
Guest
2011 KK Liberty
Normal. The tires crunch on the snow and make a noise. The traction control makes a noise. The suspension makes a noise when it's cold. Jeeps make noise
xxxxxxxxxxxxSmetna is offline
post #11 of 12 Old 01-11-2014, 01:29 AM
Bmxer524
2011 KK Liberty
The light doesn't always turn on, atleast not in my cases. When my front kicks in(from the lift mostly) it won't turn the light on.
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
post #12 of 12 Old 01-11-2014, 08:03 PM
llm317
2014 JK Wrangler
Any vehicle in 4wd will make a thumping/slightly grinding noise while making sharp turns.
llm317 is offline
