Help!! - JeepForum.com
post #1 of 8 Old 08-09-2013, 06:30 PM Thread Starter
LUV4JEEP
Help!!
Need coolant for my 2009KK what kind do I get?
LUV4JEEP is offline
post #2 of 8 Old 08-09-2013, 06:57 PM
x99j
Xerex g-05 or from the dealer. Both are the same chemistry.
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #3 of 8 Old 08-09-2013, 07:26 PM Thread Starter
LUV4JEEP
Thanks!
LUV4JEEP is offline
post #4 of 8 Old 08-09-2013, 09:52 PM
tjkj2002
2002 KJ Liberty
Be carefull as Chrysler dealers now stock Dexcool for the '13+.Make sure you get the correct HOAT coolant not the OAT coolant.
tjkj2002 is offline
post #5 of 8 Old 08-18-2013, 12:26 AM
JeepGeezer
2012 KK Liberty
Last year I flushed and refilled my 90s-era 1st-gen GC with Peak Global Lifetime Antifreeze/Coolant, diluted to 50/50 concentration with distilled water I got from Walmart. Yes I took the old coolant and rinsed fluid (I used distilled water to rinse the system out, too) to a hazardous waste disposal facility along with my other used automotive/motorcycle fluids. Yes the "lifetime" coolant costs more than standard types. This newer type coolant seems not to precipitate out on/clog the radiator passages, etc and is not supposed to eat water pump seals, etc the way the old silicate formulas did. This Peak stuff is yellow and is supposed to work in all vehicles new or old. In spite of its "lifetime" label and warranty, I still plan to flush and refill every 5 years.
I had also planned to use it in my new 2012 KK. The online service manual for my new KK warns of the need for a special procedure/equipment for eliminating air from the cooling system when refiling it after draining, due to a newer "closed" system that I suppose isolates the cooling system from the (California) atmosphere. Don't know if that procedure applies to your rig.
Check into the Peak lifetime stuff!
JeepGeezer is offline
post #6 of 8 Old 08-18-2013, 05:33 AM
tjkj2002
2002 KJ Liberty
That stuff is the wrong coolant,HOAT coolant only and that stuff is not HOAT,it's a OAT coolant.
tjkj2002 is offline
post #7 of 8 Old 08-18-2013, 01:55 PM
JeepGeezer
2012 KK Liberty
KK owner's materials specify HOAT or equivalent, which the Peak lifetime stuff is; it's rated for Chrysler MS9769, which is another way of saying for the KKs. Not conclusive, but as additional reasoning, why would a company as large as the ones making and selling Peak deliberately misstate over a period of so many years the rating of the product?
post #8 of 8 Old 08-18-2013, 04:48 PM
tjkj2002
2002 KJ Liberty
Prestone states the same thing and they only make OAT coolants,they were even court ordered to stop about 10 years ago but did not.That peak coolant is missing one chemical that is needed in your cooling system,silicates.
Go to Napa and buy Zerex GO5 coolant,gold bottle.That is the correct coolant for your Jeep.Of course the dealership has HOAT coolant also but be warned model year '13+ use OAT coolants.Ford dealerships also have HOAT coolant,there Premium Gold coolant is HOAT.
tjkj2002 is offline
