Heater Blowing Only Cold Air - JeepForum.com
post #1 of 8 Old 11-24-2013, 06:02 AM Thread Starter
nws2002
2011 KK Liberty
First issue with my 2011 KK. Just bummed it's a heater issue since the EVIC showed it to be 24 degrees this morning and it probably won't warm up much today. Just rolled of 70k miles this weekend, so obviously way out of warranty.
Left work after a night shift, got in started it up, switched on the heated seat and left. Waited for the temp gauge to hit mid-range and then turned the heat on full blast, only to start feeling freezing cold air out of the floor and defrost vents. Spun the temp dial back and forth a few times, no change. Tried turning the fan on and off a few times, fan changed speeds but still the cold air. Tried changing the air flow between the various settings, switched over between the various vents but still freezing cold air.
No anti-freeze smell or anything. I'm really hoping it's not a heater core and was wondering if there's anything simple to check and try before taking it into the dealer on Monday.
nws2002 is offline
post #2 of 8 Old 11-24-2013, 08:17 PM
Babaki
2012 KK Liberty
blend door. search the forum there are posts about it.
Babaki is offline
post #3 of 8 Old 11-25-2013, 09:28 AM
COLORADO
Stuck thermostat
COLORADO is offline
post #4 of 8 Old 11-25-2013, 10:31 AM
Babaki
2012 KK Liberty
Originally Posted by COLORADO View Post
Stuck thermostat
if he had a stuck thermostat wouldn't his temp gauge read cold all the time? he said the temp went up the middle. so to me that seems like his thermostat is working properly no?
Babaki is offline
post #5 of 8 Old 11-25-2013, 01:39 PM Thread Starter
nws2002
2011 KK Liberty
Ended up taking it to the dealership this morning, after I tried all the tricks I could find here. They replaced the HVAC box because one of the motors that controls the doors was bad. They also replaced the blower motor because it was noisy and they said there was a bearing getting ready to go out.
nws2002 is offline
post #6 of 8 Old 12-02-2013, 05:54 PM
jaws1554
water pump
just had mine changed and now have hot air.
jaws1554 is offline
post #7 of 8 Old 12-02-2013, 05:56 PM
jaws1554
water pump
took my 08 to my buddy's garage and they changed the water pump and now have hot air.
jaws1554 is offline
post #8 of 8 Old 12-02-2013, 06:01 PM
jaws1554
I have an 08 with same problem and had to put a new water pump on.
jaws1554 is offline
