post #1 of Old 10-08-2013, 06:24 PM Thread Starter
bluebuggy
heat not working
I have a 2010 kk sprot. Today I turned on the heater and got alot of cold air. The pass side had somewhat warm air.
Done a seach and found a few guys had the same problem they flushed the core and all was good. Some had to replace it.
So I done that flushed everything as good as I could started it up. It works better but not great. So I may have to swap it out.
However before I do that I have something else going on to. I let the jeep run about 15 mins got up to temperature looking it over and crack open the air port to see if any air wad there and there was but then I tured to far and the plug came out and it had to pressure. I then drove about 5 miles got out and pulled the cap off again no pressure at all.
Is this right?? Im not had any leaks or overheating so I dont think its the cap but not sure.
Anyone else have this should I just buy a cap and see if it helps?
Any help or ideas would be great
Thanks
bluebuggy is offline
You may not post new threads
You may not post replies
