Gas Gauge - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Gas Gauge
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 04-25-2010, 01:01 PM   #1
denismartynenko
Gas Gauge
Hi All! I just bought 2008 liberty and fill up the gas full tank, and Gauge needle went down to empty position and the light turns on. After about 50 miles the light goes off the needle starts going toward full tank position. I have no idea whats wrong with it.
Any suggestions???
Thanks
denismartynenko is offline   Reply With Quote Quick reply to this message
Unread 04-25-2010, 01:48 PM   #2
richd
2008 KK Liberty
Any suggestions???
Thanks
Here is a test you can do to see if its the gauge or the sender unit in the tank.With the trip meter pushed in,turn key to on,do not start engine.All you gauges should go in full right postion and slowly go back down to bottom of gauge.If your gauge goes all the way to full,then comes down slowly back to empty,then you know you have sender unit problem.
richd is offline   Reply With Quote Quick reply to this message
Unread 04-25-2010, 02:03 PM   #3
denismartynenko
Thanks I'll try that. I also was thinking of swiching the gauge wires.
