Fuse problem in my 2008 KK....NOT! A RODENT! - JeepForum.com
post #1 of 13 Old 07-11-2010, 06:16 PM Thread Starter
Huntyeraws
I had an issue with my Liberty yesterday, the key fob didn't work and when I started the vehicle, I noticed that the radio said 12:00 and the A/C and vent controls didn't work or light up. I then saw a message on the display saying - "no fuse"
I checked the fuse box - everything looked ok. I drove it and came back but it was still bugging me. The vehicle is still under warranty so I figure that it might be an electrical bug. But I checked once again, this time, I thought "out of the box" - literally and noticed a half dried up bagel along side the inside fender well and the fuse box. When I pulled this out I noticed a bunch of wires on two different wiringin harnesses had been chewed on or chewed completely through! SOB - not a warranty issue! I got a rodent! I think it is a chipmunk!
I am sure an new wirining harness isn't cheap and the labor to snake it all through is going to be fun too. At least my comprehensive damage on my auto insurance has a $50 deductable. Just a pain in the you know what.
Some times, things are not what they seem to be...
Huntyeraws is offline
post #2 of 13 Old 07-12-2010, 12:27 AM
LibertyHopeful
2008 KK Liberty
I don't know how that would be possible unless something chewed through your entire wheel liner. There are no wires exposed -- they are all safely behind the wheel liner.
Can you share a picture with us so we can get a better idea of what you're talking about?
2008 Jeep Liberty Limited 4x4
Inferno Red | Pastel Pebble Beige
uConnect GPS Power Sunroof Skid Plate Group Trailer Tow Class III Group
Pirelli Scorpion ATR 235/65R17 WeatherTech Floor Liners Mopar Cargo Tray
LibertyHopeful is offline
post #3 of 13 Old 07-12-2010, 05:25 AM Thread Starter
Huntyeraws
As I mentioned, the first time I was looking, I was looking over the fender wall and there was a white piece of material, at first, I thought it was foam covering these wiring in this area...it turned out to be a 1/2 a bagel. With the bagel removed, one can clearly see a bunch of chewed and damaged wiring on two different harnesess!
post #4 of 13 Old 07-12-2010, 06:17 AM
VMF
2008 KK Liberty
let your insurance company pay for the replacement harness
VMF is offline
post #5 of 13 Old 07-12-2010, 06:33 AM Thread Starter
Huntyeraws
Ya think I have a $50 deductable on comp!
I can just imagine the cost for the harness and the labor due to this rodent!
This is war!
post #6 of 13 Old 07-12-2010, 06:45 AM
VMF
2008 KK Liberty
i just replaced engine harness on my civic with swapped rsx-s engine, OEM acura harness was 270 and it took me 2 hours to replace. if your deductible is really 50$ then let the dealer deal wth it
VMF is offline
post #7 of 13 Old 07-13-2010, 02:27 AM
LibertyHopeful
2008 KK Liberty
Wait. You didn't just say you replaced the engine harness in 2 hours, did you? You're either captain Goodwrench or that's a load of B.S. To replace the engine harness, you have to completely remove the engine, don't you?
post #8 of 13 Old 07-13-2010, 06:43 AM
VMF
2008 KK Liberty
nah of course not! why would you need that? all engine harness is is a bunch of wires and plugs
some of the sensors are in the hard to reach places but with the car jacked it should be no problem to replace. i havent traced the harness on the liberty but im pretty confident it would not require an engine removal
VMF is offline
post #9 of 13 Old 07-13-2010, 12:38 PM
LibertyHopeful
2008 KK Liberty
Sorry, engine harness is something different for other vehicles I know.
All those wires really necessary to run the engine? 30 years ago engines didn't have all those wires! They just went KABOOM and made car go.
post #10 of 13 Old 07-13-2010, 12:47 PM
VMF
2008 KK Liberty
well we are talking about wire harness here, and thats exactly what it is, just a bunch of wires 30 years ago engines didnt use a coil per cylinder nor did they use injectors. the rest of the sensors are required to make sure that you ignition timing sensors like knock sensor, MAF sensor, o2 sensors etc etc would send all the data to your ecu and then ecu would get the optimal data from its tables to run your engine in the most optimal way. thats a simplified way ot putting it
VMF is offline
post #11 of 13 Old 07-13-2010, 02:25 PM
VMF
2008 KK Liberty
i have the same jeep as urs btw, minus the pirellis and skid plates
VMF is offline
post #12 of 13 Old 07-14-2010, 12:31 AM
LibertyHopeful
2008 KK Liberty
Where'd you get the bull bar? Looks nice. How much? Easy to install?
post #13 of 13 Old 07-14-2010, 06:51 AM
VMF
2008 KK Liberty
i found a seller on eBay and he turned out to be local, so i just went to the warehouse and picked it up there. took like 40-50 mins to install. if i remember correctly it was around 210$ cash.
VMF is offline
2008 Liberty Headlight Adjustment sbougon KK Liberty Forum 10 12-03-2013 06:02 PM
2008 Liberty mechanical fan noise JWMII KK Liberty Forum 2 11-21-2010 08:09 AM
2008 KK Spare Tire TPMS jscotts KK Liberty Forum 4 07-12-2010 07:37 PM
2008 Sport Liberty squeling when turning amike_321 KK Liberty Forum 6 01-19-2010 06:53 AM
2008 KK lift? GilNewJeeper KK Liberty Forum 6 01-05-2010 08:19 PM
