"Fumin KK" Build Thread - Page 9 - JeepForum.com
post #121 of 175 Old 07-06-2013, 06:14 PM Thread Starter
musclezmarinara
2012 KK Liberty
Originally Posted by shawnicles
And the beeamer in the background reflection
Haha that ones not mine
2012 KK Cherokee * Arctic * Mineral Gray
- Mods - See Build Thread..
musclezmarinara is offline
post #122 of 175 Old 07-06-2013, 08:53 PM
Gageraid
2008 KK Liberty
I didn't even notice that!
Gageraid is offline
post #123 of 175 Old 07-08-2013, 09:21 AM
staubitzk
2011 KK Liberty
I just ordered the OME Lift kit from Jeepinbyal but do not know which type of bump stops to get for rear. Any suggestions?
2011 Jeep Liberty Sport~OME Lift~ Tow Hooks ~ Skid Plates ~ Hitch ~ Built In Air Compressor ~ Black Rock 997s Steel Rims ~ Wrangler Duratracs ~ JK Front Mounted Lightbar ~ Tuff Stuff 22inch LED Bar ~
staubitzk is offline
post #124 of 175 Old 07-08-2013, 09:49 AM
Bmxer524
2011 KK Liberty
2 hockey pucks per side
Bmxer524 is offline
post #125 of 175 Old 07-08-2013, 10:38 AM Thread Starter
musclezmarinara
2012 KK Liberty
I was going to use the jba bump stops but as of now I'm with stock bumps.
The jba ones you have to drill .... I may use hockey pucks but I'd like to keep them more permanent.
post #126 of 175 Old 07-08-2013, 05:52 PM
Ted15
2010 KK Liberty
You still have to drill. You'll need to keep your stock bumps too.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #127 of 175 Old 07-08-2013, 06:18 PM Thread Starter
musclezmarinara
2012 KK Liberty
But I'd have to drop the rear no?
post #128 of 175 Old 07-08-2013, 06:42 PM
_benjammin
2012 KK Liberty
Why does the OME lift need bigger rear bump stops but the JBA 2.5 doesn't?
_benjammin is offline
post #129 of 175 Old 07-08-2013, 08:14 PM
Ted15
2010 KK Liberty
I'm pretty sure it does
Ted15 is offline
post #130 of 175 Old 07-08-2013, 08:23 PM
Ted15
2010 KK Liberty
I didn't. When the spring is off you'll have fairly clear access to the spring perch. I used the JBA bumps but I cut them to the proper length. I also messed up a little on the screw size, my socket didn't fit the hole in the center of the bumps, oops.
Ted15 is offline
post #131 of 175 Old 07-08-2013, 08:38 PM Thread Starter
musclezmarinara
2012 KK Liberty
What a bummer I can't remove my damn springs again I should though so I don't over stretch things.
post #132 of 175 Old 07-08-2013, 08:40 PM
Gageraid
2008 KK Liberty
What are your evil plans now with removing the springs?
Gageraid is offline
post #133 of 175 Old 07-08-2013, 09:01 PM
_benjammin
2012 KK Liberty
They (JBA) said no need. I assume it's because the shocks have enough travel and the springs won't bind, just wondering what is the limiting factor with OME.
post #134 of 175 Old 07-08-2013, 09:11 PM Thread Starter
musclezmarinara
2012 KK Liberty
I've buried my rear axle and tire into the fender but never caused damage so maybe it's not a mandatory decision?
post #135 of 175 Old 07-08-2013, 09:24 PM
Hytek
Good lookin rig :thumbup:
98 5.9 Limited - IRO 3.5", IRO short arms track bars Bilsteins, Addco, JK wheels, 255-75/17 BFG, Magnaflow, Flowmaster
04 Limited 4.7H.O QD, UC+BB, Bilsteins, 245/75-16 Duratracs Addco sway bar
Hytek is offline
"DING" Warning sound issue BigD1634 KK Liberty Forum 12 11-15-2012 02:16 AM
08 Liberty Rough Idling in "Drive" Luch466 KK Liberty Forum 4 11-22-2011 10:58 AM
Tire sensor values and the "dealer" severewinds KK Liberty Forum 5 10-30-2011 07:18 AM
Reseting "Change Oil" Notification BloodyShadow23 KK Liberty Forum 8 07-01-2011 07:49 AM
2010 Liberty "Renegade" with Transmission Vibration davebwi KK Liberty Forum 4 08-09-2010 11:39 AM
