Little of both. I would have favored a matt black finish with a more aggressive stance. The Liberty is stunning though! I have a silver '11 Jet 4X4, and the deeper color is awesome! I like the badging throughout as well! Planning any mods anytime soon?
Where did you get the plugs from? I also don't have a front plate but have two holes that look kinda crappy on the front bumper where the dealer advertisement plate was.
I totally understand. If mine was brand new I would probably spend the $25, but I have an 08' with battle scars and rock chips all over the front already. Let's see those pics! I am getting that same lift with skyjacker hydro shocks in a couple weeks while I am back home for the holidays.
The build looks really good, man! I'm sure pics don't compare to standing next to it and seeing it in person - but nice job! Are you gonna do spacers? They would really make those rims and tires pop and would give it an aggressive stance.
Looks sick. Love the color. I've had the same lift on for 6 months and it still rides good. How do you like the rear shocks? Did you buy new emblems then paint them or remove your old ones?
Musclez - when you measure your lift at the fender wells do it from the center of your hub to the fender well. It will give a more accurate read of your lift and not be effected by the tire size. It looks like you increased your ground to rails clearance pretty significantly - did you take before measurements?
Update just ordered OME Springs to replace the daystar garbage
Bilstein Shocks Front
Bilstein Shocks Rear
3 conduits clevis lift per side up front
1/4 top plate
JeepinByAl Rear Bump Stops Rear Bump Stop 4"
Tera flex bump stops up front
OME 2948 Rear
OME 2927 Front
hopefully will give a bigger lift than current setup/
Do they make a difference in the lift/ride? Also, are there factory coil isolators and if so, can they be reused?
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
