Front tweeters - JeepForum.com
post #1 of 18 Old 01-04-2012, 08:56 PM Thread Starter
Elkete
2008 KK Liberty
Front tweeters
I'm trying to remove the tweeters in the dash but I don't know how take them out and put the new ones in can somebody help, if u have pic even better thx
Elkete is offline
post #2 of 18 Old 01-08-2012, 09:38 AM
SlapStik
2008 KK Liberty
Go to Crutchfield.com and input your car. Go to Outfit My Car then to the speaker section and select a set of speakers for the front and click on them. The speakers will come up with a list of included items that also includes an installation guide for the tweeters. Good luck
SlapStik is offline
post #3 of 18 Old 01-08-2012, 06:46 PM
Skipper6413
2011 KK Liberty
Crutchfield only puts out vague guidance and no pics. For the detailed "how to," they expect a purchase.
Skipper6413 is offline
post #4 of 18 Old 01-09-2012, 06:13 AM
LibertyRS
2012 KK Liberty
start popping out the dash. until you get to the speakers. i put it in my whole nav in my dash just going for it. the only thing i looked up was the wire layout
2012 Jeep KK
Stormtrooped
ZZzz
LibertyRS is offline
post #5 of 18 Old 01-09-2012, 09:59 AM
TMD78
I would also be interested in dash removal pics to access the tweeters. Crutchfield doesn't really acknowledge the panel speakers and my local audio shop would not install the 3.5's that I purchased to replace them because they were concerned about my jeep being too new to risk pulling the whole dash and disturbing the airbags? The center area just pops off with clips but I'm having a hard time finding a good walkthru for the upper dash.
TMD78 is offline
post #6 of 18 Old 01-09-2012, 11:15 AM
LibertyRS
2012 KK Liberty
Once i get some time ill post pics of dash removal. I dont know when that is though. Honestly you just gotta go for it. Airbags you dont have to worry about i think. I have 2012 lib and i just went to town on it.
2012 Jeep KK
Stormtrooped
ZZzz
post #7 of 18 Old 01-09-2012, 07:02 PM
quikgt
2008 KK Liberty
What good is an audio shop if they won't do install on a new vehicle?
quikgt is offline
post #8 of 18 Old 01-09-2012, 09:48 PM
TMD78
Gotta agree with you. I always do things myself but because of the cold I went to a shop. I told the guy they have to be better equipped than I am to do the install and he just wouldn't go for it. Could be the 10 people behind me trying to get their Christmas remote start installed. Hoping to see some pics before just going for it.
TMD78 is offline
post #9 of 18 Old 01-09-2012, 11:12 PM
VegasDragger45
2010 KK Liberty
I saw a how to before but not sure where. You first remove the center dash bezel. Once that is done you need to remove the two top vent covers you have to remove the left side first sine it over laps the right side. Once they are gone you need to remove both a-pillars once they are off or loose you need to remove the screw holding the bezel in. It is located right next to the speaker grill there is one for each side. So now focusing on the drivers side the vent, speaker grill, and cluster bezel are all one piece you need to pull towards you and it will release the clips holding it in. The passenger side you need to remove the grab handle as well which has two Phillips screws that you access through the glove box. Once those are removed you just pull towards you like you did with the driver side. I had to lift up the right outer edge of the air bag to pull the panel out but you don't move it enough to worry about.
2010 KK, 2" Daystar lift, 245/75/16 BFG All-Terrains, interior LED's, front rear and cargo liner weather tech's, Pioneer AVH-p4400BT, GEX-P920XM, Kicker 6" in front 5 1/4" in rear, PB 2.75" in dash, Kicker 300.1 amp, Pioneer TS-SWX310, JK light bar with Hella 500 ff and 100w bulb, BOYO rear view camera, JBA exhaust, K&N drop in filter and more to come.
VegasDragger45 is offline
post #10 of 18 Old 01-10-2012, 04:08 PM
Dave_B
2008 KK Liberty
Look over on LOST I think there is a how to on the dash in the tech section.
Dave
Lovin' my CARBON FOOT PRINT!
Dave_B is offline
post #11 of 18 Old 01-10-2012, 09:24 PM
TMD78
Dave
Thanks for the heads up! http://www.lostjeeps.com/forum/phpBB...?f=104&t=29455
TMD78 is offline
post #12 of 18 Old 01-13-2012, 05:32 PM Thread Starter
Elkete
2008 KK Liberty
Thanks tmd78 I will change it next week
Elkete is offline
post #13 of 18 Old 01-13-2012, 05:35 PM Thread Starter
Elkete
2008 KK Liberty
Thanks tmd78 and vegasdragger45 for your help
Elkete is offline
post #14 of 18 Old 01-28-2012, 11:45 AM
TMD78
I finally got around to working on the dash speakers today. Know ahead of time that 3.5" speakers WILL NOT FIT without some creative cutting of the plastic trim that the factory speakers mount to. I cut out the back right original mounting area to make mine fit.
TMD78 is offline
post #15 of 18 Old 01-28-2012, 03:35 PM
TMD78
I guess it's also worth adding that the factory trim that has the speaker grill as part of it, only has an opening of about and inch or so. So basically you are covering up alot of the sound you hope to gain. If I had it to do over I'd have just gone with the factory kicker upgrade since it is a component setup with the tweeter ready to mount in the stock location.
TMD78 is offline
2008 Tweeters jeepfreak108989 KK Liberty Forum 3 07-10-2011 06:40 AM
