Front Driver Side Tire Change Issue - JeepForum.com
post #1 of 15 Old 09-25-2013, 07:02 AM Thread Starter
KevinNJ25
I woke up this morning to find my front driver side tire flat. As instructed I cracked the lugs, raised the vehicle and finally fully unscrewed the lugs. Tire was ~2-3" off the ground at this time. I used every bit of stength but the tire wouldnt seperate from the hub.
I read and reread the directions in the owners manual 3 times and know I am doing everything correct.
What the heck?
KevinNJ25 is offline
post #2 of 15 Old 09-25-2013, 07:39 AM
Babaki
2012 KK Liberty
probably rust. kick it a few times to free it up.
Babaki is offline
post #3 of 15 Old 09-25-2013, 07:55 AM Thread Starter
KevinNJ25
I'll give it a swift few kicks after work...thanks for the input
post #4 of 15 Old 09-25-2013, 08:01 AM
tommudd
2004 KJ Liberty
3 lb hammer against the tire ( not wheel ) will knock it loose
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #5 of 15 Old 09-25-2013, 09:30 AM
khalilw
2011 KK Liberty
Same thing happened to me years ago with my old car, a Chevrolet Optra, what I did was spill some water over the wheel hub and kick the tire everywhere, after 30 kicks and a 2Lts bottle of water, the tire came off.
khalilw is offline
post #6 of 15 Old 09-25-2013, 10:07 AM
Gageraid
2008 KK Liberty
x2
Gageraid is offline
post #7 of 15 Old 09-25-2013, 11:06 AM
AtTheHelm
Donkey kick
AtTheHelm is offline
post #8 of 15 Old 09-25-2013, 12:43 PM
JeepGeezer
2012 KK Liberty
Remember that jack stability is factor here in kicking/hammering. If light kicking/hammering does not loosen the wheel, does it make sense to then carefully apply a very small amount WD-40/rust penetrant at lug-wheel points first and lightly/moderately tap on tire all the way around to help penetrate rust? (Taking great care not to get penetrant on rotor/pad-rub area!!!) Let penetrant work a few minutes and then try again to lightly/moderately tap/kick wheel to remove it?
JeepGeezer is offline
post #9 of 15 Old 09-25-2013, 01:48 PM
tommudd
2004 KJ Liberty
Water nor WD-40 will not do much at all to loosen a wheel , may as well pee on them
You need something to knock the rust right away
PB Blaster or Aerokroil works well
but still the best thing is a couple of good smacks with a 3 lb or larger hammer
was in the tire business long enough to know there's very few that won't come off that way
Plus how long has it been since you rotated your tires, if like you should every 3-4000 miles no way should it be rusted on
MUDD'S MOTORSPORTS
tommudd is offline
post #10 of 15 Old 09-25-2013, 07:57 PM
tjkj2002
2002 KJ Liberty
x2.........................
If I have to break out my 4lbs deadblow to take your wheel/tires off due to corrosion you need to wash your vehicle better(not just the painted shiny part) and rotate your tires more often.
tjkj2002 is offline
post #11 of 15 Old 09-25-2013, 08:04 PM
Jeffro06
Jeffro06's Avatar
Set tire back on ground, turn wheel just a bit, pop goes the wheel.....I had to do this for a lady once on the side of the road as there was no other way to break the wheel free. Worked like a charm, no hammer required.
Jeffro06 is offline
post #12 of 15 Old 09-26-2013, 03:49 PM
JeepGeezer
2012 KK Liberty
I'm assuming you do the above with wheel nuts loosened a bit, like finger-tight, or? I have always rotated tires regularly and have never had the original poster's problem, but would like to more-precisely understand this tecnique for breaking loose stuck wheel, just in case!!! When I have rotated tires I also often flushed brakes/inspected the surrounding areas (brake hoses, struts/shocks, etc for cracks, leaks, rubbing. etc.) while the wheels are off, and steel brushed the rotor-wheel faces as a best practice for better contact, etc.
(I have often successfully used the WD-40 application/tapping/waiting method for stuck threads on various other items, tho.)
post #13 of 15 Old 09-26-2013, 06:25 PM
Jeffro06
Jeffro06's Avatar
Yes the lugs were loose, but not so loose the wheel was going to fall off. I had kicked the tire so hard it almost knocked the PT Cruiser off the jack, so I decided to try a different route, so I set it on the ground, with the lugs on a bit, then turned the wheel, slightly....popped right off.
Anti-seize is always your friend.
Jeffro06 is offline
post #14 of 15 Old 09-26-2013, 11:15 PM
JeepGeezer
2012 KK Liberty
Got it now! Makes perfect sense. Thanks.
post #15 of 15 Old 09-27-2013, 05:15 AM
Jeffro06
Jeffro06's Avatar
Of course this only works on the front tires......
Jeffro06 is offline
